Eagle DRD File Parsing Engine
idbruce
Hi All
This may not be much use to a lot of you, but for those interested in CNC control and circuit board creation, here is an Eagle drill file parser.· I will post it in the object exchange with enhancements in a couple days.· Until then, here it is.· Metric support is not provided.· [noparse]:([/noparse]
Bruce
Bruce
Before you say it......· [noparse]:)[/noparse]
Yes I know.....·· Regular expression would have cut the code to a small fraction and been much easier and less time involved
Bruce
The time has come to resurrect some old code.
I am currently working on my new design of the CNC PCB Drilling Machine, and when I get tired of working on it, like I am now, I will be dedicating much of my time to getting this code into much better shape. The code above will be revamped to include the PulseTheStepPin function from the attached code below, to enable the use of a pulsed step pin stepper motor driver, such as the G251X from Gecko Drive. In addition to that, I will probably alter the code to have conditional case statements instead if(s), as well as other changes.
Bruce
My CNC PCB Drilling Machine is now much closer to a reality. At this point 60 holes have been drilled into the aluminum blanks and the parts are starting to shape up. I am starting to get a little excited and a little ambition has returned, because I know that very soon, I will have nice and new piece of automated machinery for making PCB prototypes very quickly.
I really have not put any time into revamping this code, except for giving everything the once over. However, during the machining processes, I have put a lot of thought into the software. I will share some of these thoughts with you now, just so you know where the software will be heading. Since the software will be based upon the hardware I want to have, I believe this will be my main topic of discussion, with the exception that I now want the driller to support several different types of drill files, instead of just Eagle, and I also want it to support the metric system.
Without making this too lengthy, I will simply mention the hardware or component with a brief discussion.
Bruce
