Pasm divide by 10 and 100
Hello,
Is this less efficient, more efficient or no difference to any other PASM ways to divide by 10 or 100? 50,000/10 = 6776 clk cycles, 1,500,000/10 = 11,320 clk cycles. 50,000/100 took 1404 clk cycles, and 1,500,000/100 took 1848 clk cycles. I know that when you get closer to 0 or closer to 2 billion (for the number * modifier) the numbers aren't as exact, but I think they are close enough for me so far.
I tried to figure out the long way to do this in a loop, and didn't have any success. I can't attach the project because of the work firewall, but here is the gist of it.
I'd like to be able to divide by any number though, with self modifying code and I'm not sure how to do that.
CON _clkmode = xtal1+pll16x _clkfreq = 80_000_000 OBJ DEBUG : "FullDuplexSerial" ' for debugging VAR LONG retblock, done, pst1, pst2, pst3, pst4, pst5, pst6, pst7, pst8 PUB Main DEBUG.start(31, 30, 0, 115200) waitcnt(clkfreq + cnt) cognew(@math, @retblock) repeat debug.dec(pst1) debug.tx(13) debug.dec(pst2) debug.tx(13) debug.dec(pst3) debug.tx(13) debug.dec(pst4) debug.tx(13) debug.dec(pst5) debug.tx(13) debug.dec(pst6) debug.tx(13) debug.dec(pst7) debug.tx(13) debug.tx(13) debug.dec(pst8) debug.tx(13) debug.tx(13) debug.tx(13) waitcnt(clkfreq + cnt) DAT math add pstptr1, par ' @pst add pstptr2, par ' @pst2 add pstptr3, par ' @pst3 add pstptr4, par ' @pst4 add pstptr5, par ' @pst5 add pstptr6, par ' @pst6 add pstptr7, par ' @pst7 add pstptr8, par ' @pst8 mov par1, fiftyK MOV par2, #5 'call #divideByTen call #divideByHun jmp #end' /10 divideByTen mov startCnt, cnt mov divideByTenLoopCnt, #205 mov dividedByTenSum, #0 wrlong divideByTenLoopCnt, pstptr2 :div add dividedByTenSum, par1 ' multiply by 205, by adding the value 205 times wrlong dividedByTenSum, pstptr3 wrlong par1, pstptr1 djnz divideByTenLoopCnt, #:div shr dividedByTenSum, #11 ' divide by 2048 (net divide by /10) by shifting the value right by 13 wrlong dividedByTenSum, pstptr4 mov subSkew, #0 mov numTemp, par1 :rem cmp numTemp, divideByTenSkew WZ, WC if_z_or_nc add subSkew, #1 if_z_or_nc sub numTemp, divideByTenSkew if_z_or_nc wrlong subSkew, pstptr5 if_z_or_nc jmp #:rem mov endCnt, cnt mov dividedByTenSumT, dividedByTenSum sub dividedByTenSumT, subSkew wrlong dividedByTenSumT, pstptr6 sub endCnt, startCnt wrlong endCnt, pstptr7 MOV ret_val, dividedByTenSumT ' return product divideByTen_ret RET ' /100 divideByHun mov startCnt, cnt mov divideByHunLoopCnt, #41 mov dividedByHunSum, #0 wrlong divideByHunLoopCnt, pstptr2 :div add dividedByHunSum, par1 ' multiply by 205, by adding the value 205 times wrlong dividedByHunSum, pstptr3 wrlong par1, pstptr1 djnz divideByHunLoopCnt, #:div shr dividedByHunSum, #12 ' divide by 2048 (net divide by /10) by shifting the value right by 13 wrlong dividedByHunSum, pstptr4 mov subSkew, #0 mov numTemp, par1 :rem cmp numTemp, divideByHunSkew WZ, WC if_z_or_nc add subSkew, #1 if_z_or_nc sub numTemp, divideByHunSkew if_z_or_nc wrlong subSkew, pstptr5 if_z_or_nc jmp #:rem mov endCnt, cnt mov dividedByHunSumT, dividedByHunSum sub dividedByHunSumT, subSkew wrlong dividedByHunSumT, pstptr6 sub endCnt, startCnt wrlong endCnt, pstptr7 MOV ret_val, dividedByHunSumT ' return product divideByHun_ret RET /1000 divideByThou mov startCnt, cnt mov divideByThouLoopCnt, #4 mov dividedByThouSum, #0 wrlong divideByThouLoopCnt, pstptr2 :div add dividedByThouSum, par1 ' multiply by 205, by adding the value 205 times wrlong dividedByThouSum, pstptr3 wrlong par1, pstptr1 djnz divideByThouLoopCnt, #:div shr dividedByThouSum, #12 ' divide by 2048 (net divide by /10) by shifting the value right by 13 wrlong dividedByThouSum, pstptr4 mov subSkew, #0 mov numTemp, par1 :rem cmp numTemp, divideByThouSkew WZ, WC if_z_or_nc add subSkew, #1 if_z_or_nc sub numTemp, divideByThouSkew if_z_or_nc wrlong subSkew, pstptr5 if_z_or_nc jmp #:rem mov endCnt, cnt mov dividedByThouSumT, dividedByThouSum add dividedByThouSumT, subSkew wrlong dividedByThouSumT, pstptr6 sub endCnt, startCnt wrlong endCnt, pstptr7 MOV ret_val, dividedByThouSumT ' return product divideByThou_ret RET end 'MOV p1, PAR WRLONG ret_val, pstptr8 'ADD p1, #4 'WRLONG negone, p1 COGID p1 COGSTOP p1 ' -------------------------------------------------------------------------------------------------- retblkptr long 0 doneptr long 4 pstptr1 long 8 pstptr2 long 12 pstptr3 long 16 pstptr4 long 20 pstptr5 long 24 pstptr6 long 28 pstptr7 long 32 pstptr8 long 36 par1 LONG 0 par2 LONG 0 ret_val LONG 0 divideByTenLoopCnt long 419431 divideByTenLoopCnt2 long 0 divideByTenLoopCntT long 205 divideByHundredLoopCnt long 41944 divideByTenSkew long 10273 dividedByTenSum long 0 fiveK long 5000 tenK long 10000 elevenK long 11000 fifteenK long 15000 twentyK long 20000 twentyFiveK long 25000 FiftyK long 50000 oneHundredFiftyK long 150000 onePtFiveMil long 1500000 fifteenMil long 15000000 fiftyMil long 50000000 subSkew long 0 numTemp long 0 dividedByTenSumT long 0 startCnt long 0 endCnt long 0 divideByHunLoopCnt long 41 dividedByHunSum long 0 dividedByHunSumT long 0 divideByHunSkew long 102731 divideByThouLoopCnt long 4 dividedByThouSum long 0 dividedByThouSumT long 0 divideByThouSkew long 41943 p1 RES FIT 496
Just put the thing you want to divide in the dividend and the thing you want to divide by in the divisor. Then the result will appear in the quotient and the remainder will appear in the dividend.
I have used a techique like yours for processors that have a single-cycle multiply. You are approximating 1/10 as 204.8/2048. The value of 205 has an error of 0.1%, so you could use this technique to handle numbers that have a limited range. You need to add 1024 before shifting down by 11 bits to round. I didn't notice if your code did that. You also need to implement the multiply by 205 in a more efficient way. 205 is equal to %1100_1101. So you could implement this as follows:
EDIT: Of course, in Spin it would be much more efficient to just do x/10. However, this technique should be fairly efficient in PASM.
http://www.hackersdelight.org/divcMore.pdf
Jonathan
Thanks for this code, I tested it and was quite happy!
Thanks for your replies, I did not think of the rounding technique, that was brilliant, I tried it in my code and it worked well and makes complete logical sense! So does the shift by X to get to 205 faster, rather than an add routine.
I tried Kye's object and it worked well, do you see any advantage to not using that for a /10, since it appears it can divide just about any number and is not limited to /10 or /100?
Is there a repository where I can look up a spin command and then view the routines the interpreter uses? That would be a huge help to PASM beginners like me.
May I propose a fast and very accurate algorithm for the division by 10?
As you know, division by 10 is the same as to multiply with 0.1.
2^20 is 1_048_576. It is easy to divide with this number in PASM.
104_856 / 1_048_576 is about 0.0999985, some 2ppm accurate to 0.1
However, 104_856 factorisable as 2^3 x 3 x 17 x 257. In other words
104_856 = 2^3 x (2^2 - 1) x (2^4 + 1) x (2^8 + 1)
This means that it is easy to multiply with 104_856 in PASM with left
shifts and additions/subtraction.
The very pseudo algorithm goes as follows:
Rotate argument 1 left
Subtract original argument
Rotate new argument 2 left
Add new argument to result
Rotate result 8 left.
Add previous result once to it.
Rotate final result 17 times right.
(See some similar code in Dave Hein post)
I guess this will take about 12-15 machine cycles and can be used
up to 40_000 without error.
Cheers,
Istvan
Thanks for your post. I have never used a rotate command for math before, I guess that would be RCL/RCR in PASM?
Kye kind of gave me the "keys to the castle" when he gave me this code below, I just call it and then return a value to a variable, I don't know if your way is faster, but this was from the spin interpreter and I've just been using this as I spent days working on an algorithm and I use this just like an object when I call it.
Kye's code is a fast and optimized "traditional" binary division, that always takes about 104-116 machine cycles.
Its main advantage here, that it works with arbitrary arguments. If speed matters, it is an overkill for just dividing
small numbers with 10.
Dave Hein PASM code takes only 10 machine cycles. 10 times faster than the full division, but the result is
correct only for arguments less than 1027.
My method should be implemented in PASM with less than 20 machine cycles. Slower, but works correctly
up to 32K dividends. The interesting thing about it that the factorization of the multiplier (104_856) contains
only numbers that are powers of two plus/minus one (3, 17, 257). This allows for effective PASM coding.
In my previous answer I should wrote shift instead of rotate. One step shift of the binary numbers to the left
or the to the right is multiplication or division by two, respectively. For example to divide by 8 just shift
3 times to the right:
in PASM SHR dividend, #3 (1 machine cycle)
in SPIN dividend>>3 (Much less machine cycles than of "dividend := dividend / 8")
You can use rotate in binary arithmetics in many cases, usualy combined with carry to handle over or
underflow, for example.
Clarify "machine cycle" - its highly ambiguous to my mind...
Hi Mark,
I see, you even coded it long before I "found" it. It is only 12 machine cycles. 4 clock ticks
needed for the Prop for 1 instruction cycle, which I call 1 machine cycle, maybe because of
easier spelling.
Did you note, that one can expand the range of arguments with correct result by distributing
the 17 left shifts inside/after the multiplications? Maybe one can make a 31-bit divide_by_10
routine from your code.
