Using 18 Volt Tool Batteries
Bill Chennault
All--
In my next project, I would like to use an 18v battery compatible with my cordless tools. The 18 volt Ryobi comes to mind. But, my favorite motor controller--the HB25--has a 16 volt maximum input. I use gear motors that have a stated max of 15 volts with a stall current of 21A, but I am sure I have never drawn more than 3 - 5 amps. Of course, I also need to get some power at acceptable Propeller Vin levels, too.
Is there a practical solution using the Ryobi (or similar) battery or should I abandon that idea?
Thanks.
--Bill
Thanks.
--Bill
What is the Ah rating the battery packs you want to use? Are they going to give you a long enough run time? On my larger robots I've been using SLA type batteries. I try to use standard sizes (7ah, 17ah, etc) so they are easy to get. On my latest robot I want overboard and went with a 55Ah battery but it can handle the weight and I wanted a long run time... With the 12V you can often use some of the smaller automotive chargers since many now have a setting for SLA batteries. If you stick with 12V you can use the HB-25's.
If you stay with the 18V packs and can't use the HB-25's then you may want to checkout the Scorpion XL since it will handle those batteries and shouldn't have any trouble with the current.
http://www.robotpower.com/products/scorpion_XL_info.html
http://www.robotpower.com/catalog/
Robert
http://www.ehow.com/how_5991322_rejuvenate-sla-batteries.html
I found those cheapie Ebay NiMH batteries I posted about to be quite useful, even though they are really 900 mA cells. Easy to make any voltage by the number of cells, and easy to make a trickle charger out of nearly any old AC adapter. For several recent projects (robot arm and robot arm printer) I just use 4 cells for 5 volts direct in, no voltage regulator required.
I have a lot of LiPo & Li-ion batteries too. They're lightweight and great in the right app, but charging Li-ions is problematic. Loopy Byteloose posted about some AA sized Li-ion's a while back, #14500. I like those, and the fact that you can put 'em in an existing AA battery holder is a plus. Just don't use them in an existing product made for AA cells or you'll see the magic smoke. 3 of those 14500 AAs drove my 12V relay board at Expo all weekend.
http://www.ebay.com/itm/2-x-3-7V-1200mAh-ICR-14500-AA-Li-ion-Lithium-Rechargeable-Protected-Battery-New-/140651808043?pt=US_Batteries&hash=item20bf80452b
http://www.amazon.com/Tenergy-Li-Ion-Cylindrical-Rechargeable-800mAh/dp/B003BHDP4C
The only reason I wanted to use the 18 volt Ryobi P103 is because my next door neighbor and I kinda sorta decided to standardize on Ryobi tools using that battery. (I'm sure that will change as soon as one of us sees the next, new, neat thing, or n3thing.) Twelve volts would sure suit my electrical requirements better. I just thought it would look COOL to be able to slap one of those Ryobi battery packs into my robot.
The Ryobi P103 is a 24 watt-hour battery. I am not sure how to equate that with the two motors I want to use, which are my Banebot RS-545 gear motors. Perhaps the P103 is totally inappropriate, power-wise. I have been using dual, 12 amp hour, sealed, lead acid batteries. They are bulky, but provide all the power I need. (Far more, actually.)
I do not have to use either the Banebot RS-545 motors or the Ryobi P103 battery. If I switched to the RS-775 18v (6v-20v) motor, then I suppose the Ryobi P103 would work from the voltage standpoint. (I don't know about amp hours, though. Maybe I would use TWO P103s. Now, that would look neat!)
--Bill
The 24 watt hours would be 1.33 Amp hours (watt hours = amp hours x voltage), so pretty small compared to what you are using. I have used DeWalt 18V batteries to run my laptop for extended periods and that works pretty well.
Thank you for explaining it to me. And, you're right, that would be tiny compared to what I am using. I don't think even two of them would be sufficient for the motors I use.
--Bill
Hacking: http://www.slkelectronics.com/DeWalt/packs.htm
Refurb $124! http://www.ebay.com/itm/DeWalt-DC9360R-H-Duty-36V-NANO-Battery-Pack-WARRANTY-/180790716773?pt=US_Power_Tools_Batteries_Chargers&hash=item2a17f76965
I am a bit surprised that a cordless tool battery would be so anemic. Not sure what my 18V DeWalt batteries are rated at but a charge is good for 2 to 3 hours of driving screws to mount hardware. When I used one as a substitute for my laptop power brick it let me use the laptop for a full 8 hour day.
I think those batteries are rated at 3 or 4 amp hour
Where did you get the power cord for your laptop to use a 18V DeWalt batteries to power the laptop
The obvious solution is to build your own H-bridge out of TIP120s amd TIP125 or similar power MOSfets. Those 18 volt batteries are likely to charge to beyond 20VDC and then drop to something like 14VDC under loads.
If you really want to use all that you have - the 18VDC battery, the HB25, and the 15VDC motors -- just get some large rectifier diodes (like 10 amp) and use them to knock down the 18VDC to 15VDC. At .6volts each, a series of 5 should do the job. But test that battery for its real peak voltage - never trust the lable.
The connector to clip on the battery came from a dead battery charger and the cord and barrel connector to plug into the laptop came from a dead power brick. Recycling at it's finest. With a fully charged laptop and DeWalt battery I have been able to run for a full work day.
