Another dumb question - Parallax Serial Terminal
Hi again everyone.
I'm trying to have a play with the PST object but am doing something very wrong.
Here is my code
CON
_clkmode = xtal1 + pll16x ' Crystal and PLL settings.
_xinfreq = 5_000_000 ' 5 MHz crystal (5 MHz x 16 = 80 MHz).
OBJ
pst : "Parallax Serial Terminal" ' Serial communication object
VAR
long name
PUB go
pst.Start(115200) ' Start the Parallax Serial Terminal cog
Replace the code below with your test code
pst.Str(String("My Kakky Hello Code"))
pst.Chars(pst#NL, 2)
pst.Str(String("Please enter your name:- "))
pst.StrIn(name)
pst.Str(String(pst#NL,"Hello "))
pst.Str(String(name))
pst.Str(String(", Pleased to meet you."))
Can anyone tell me why I'm so stupid and what I'm doing wrong?
Is there a site anywhere with a tutorial on the PST object? I'm trying to decipher it's functions from the object itself but obviously not doing a good job
Thanks in advance
Here is my code
CON
OBJ
VAR
long name
PUB go
pst.StrIn(name)
Thanks in advance
Also, in the future please make sure to use the [ code ] tags instead of just pasting the code into your post.
I'll make sure I add the tags in future
Use this:
The you also need to use the address of the string.
I've put the prop away for tonight but I'll add your changes in the morning
That's exactly the sort of info someone like me needs
