Another dumb question - Parallax Serial Terminal
Hi again everyone.
I'm trying to have a play with the PST object but am doing something very wrong.
Here is my code
CON
_clkmode = xtal1 + pll16x ' Crystal and PLL settings.
_xinfreq = 5_000_000 ' 5 MHz crystal (5 MHz x 16 = 80 MHz).
OBJ
pst : "Parallax Serial Terminal" ' Serial communication object
VAR
long name
PUB go
pst.Start(115200) ' Start the Parallax Serial Terminal cog
Replace the code below with your test code
pst.Str(String("My Kakky Hello Code"))
pst.Chars(pst#NL, 2)
pst.Str(String("Please enter your name:- "))
pst.StrIn(name)
pst.Str(String(pst#NL,"Hello "))
pst.Str(String(name))
pst.Str(String(", Pleased to meet you."))
Can anyone tell me why I'm so stupid and what I'm doing wrong?
Is there a site anywhere with a tutorial on the PST object? I'm trying to decipher it's functions from the object itself but obviously not doing a good job
Thanks in advance
Here is my code
CON
OBJ
VAR
long name
PUB go
pst.StrIn(name)
Thanks in advance
Also, in the future please make sure to use the [ code ] tags instead of just pasting the code into your post.
I'll make sure I add the tags in future
Use this:
The you also need to use the address of the string.
pst.Str(String("Please enter your name:- ")) pst.StrIn([B]@[/B]name) pst.Str(String(pst#NL,"Hello ")) pst.str([B]@[/B]name)I've put the prop away for tonight but I'll add your changes in the morning
That's exactly the sort of info someone like me needs
