Very cheap robot chassis
I just got an email from Cool Components listing their new products, and this caught my eye:
http://www.coolcomponents.co.uk/catalog/magician-robot-chassis-p-975.html?utm_medium=email&utm_campaign=d1489db428-April_Newsletter_2012&utm_source=Newsletter+List
I've ordered one.
I've ordered one.
SparkFun also sells the Magician chassis.
These have been talked about here on the forum a bit. I think Rayman makes a board (Merlin IIRC) to connect with a QuickStart that makes driving the robot easier.
I have one of these chassis. I broke one of the pieces trying to assemble it and I postponed building it until I find the acrylic glue I purchased not too long ago.
One of these summers, I hope to hold a small robot summer school so I'm on the look out for inexpensive robots. I'm not sure if I'd want to use a kit like the Magician with motors to drive directly or to use CR servos.
"Cheap" is the right word to describe it... Maybe the biggest problem is that it doesn't aways exactly drive in straight lines...
Still, for some people, price is everything and I think this is the lowest price robot out there...
What are your plans for the robot?
I've been putting Nordic nRF24L01+ modules in most of my robots to use them remotely. I'll probably add a Nordic module with a QuickStart to my Magician. Of course it will need some sensors. A robot's not a robot if it can't move on its own (and not just by radio control).
I'm working on a remote for my various robots. It uses one of Rayman's 4.3" touchscreens with a PlayStation 2 controller.
Just last night I learned how to read the pressure information on the PlayStation 2's buttons. So now, instead of just the four analog inputs from the joysticks, there will be a total of 16 analog inputs.
BTW, while I'm rambling, I thought I'd mention, don't trust generic game controllers. The PlayStation 2 clone SparkFun sells only has 5-bits of precision on its joysticks (they should have 8-bits of precision).
I'd say this is a decent chassis if you can get the right motors on it. You'll know what motors you got when you try to back drive them. The low-torque version offers little resistance. They're probably no more than about 50:1.
-- Gordon
PS: I forgot to mention Step 1 in building the Magician: Find the included screwdriver and throw it away. It'll chew up the heads of the screws.
I saw the encoders, they are called "Speed board holders". If they are used I don't see why accurate control can't be achieved.
Makes me wonder if the same company sells the "speed boards". In that case, they would purposely use mismatched motors in their Magician kit to make sure you subsequently bought their speed boards to solve the problem and go straight!
Heck, selling patches and upgrades has worked for Microsoft for many years now. When does Windows Ten come out?
Also, the speed board holders don't fit the shafts very well, and one is very sloppy. It is a good fit on the outer shaft, though! I might have to use some glue on them.
One of the motor brackets was a lot thicker than the others, and wouldn't fit the holes, so I used it in an outer slot.
It looks as though their manufacturing tolerances are very wide.
Tolerance is a wonderful thing! We even have a Museum of Tolerance here in Los Angeles. I should visit it to see if the Magician chassis is featured therein.
http://www.museumoftolerance.com/site/c.tmL6KfNVLtH/b.4865925/k.83A7/Whats_Happening_at_the_MOT.htm
On those speed thingies: Being red, and not even 100% opaque to white light, they are fundamentally transparent to near IR. If you want to use them as encoders you'll need to apply several coats of heavy black or other IR-opaque paint to them. While not symmetrical, when counted as high- or low-going pulses and averaged out over a half-second or second, they'll do okay as distance counters.
Because the speed differences between the motors can be so sudden and drastic any encoder system will have to work overtime to keep the thing going straight.
-- Gordon
I assembled my Magician chassis tonight and I was pleasantly surprised how well the laser-cut acrylic pieces fit together. The motor plates & screws were snug. The only questionable/sloppy fits were the battery holder screws. My main dislike is that cheap steel caster ball. Erratic friction induces random drifting. I don't know why some people think they're a plus. CBA's drawer pull (dragging on the ground) would offer more consistent performance.
Motors are definitely geared too high, but with some attention to detail, I got it driving in a nice straight line on 3V. The wheels can rub the chassis, which will cause erratic turning. I'll switch to much lower geared motors at first opportunity, the manufacturer should follow suit.
One pair have similar motors as the stock motor and operate predictably at nearly half the speed of the stock motors (good). The other pair have different motors and rotate MUCH slower with gobs of torque (great).
-- Gordon
-- Gordon
