Please help me with BS2 code for school robot project. Pic and code included!!!! — Parallax Forums
Tony_tsiTony_tsi Posts: 98
edited 2012-05-20 14:03 in BASIC Stamp
I am building a robot for school. I do not use basic stamp very often and I need help with a select...case statement. The select statement needs to select inputs 9-15. The code is very simple. I need a line to replace ( SELECT IN9-IN15 )
The code for the robot is in the link below.
code for robot.bs2
  • Tony_tsiTony_tsi Posts: 98
    edited 2012-04-17 13:07
    I should add that the line ( SELECT IN9-IN15 ) looks good but doesn't work.
    edited 2012-04-17 13:12
    Your select condition, SELECT IN9-IN15, subtracts one bit input from another. Instead, try,
    SELECT INS >> 9
    This takes all 16 input bits as a word, and shifts it right by 9 positions, leaving bits 15..9 in positions 6..0.
    But even then, I'm not sure that's what you want. Pins 15..9 represent seven pins, but your conditions use only six.
    edited 2012-04-18 07:56
    It may or may not be relevant to which type of sensor being used whether infrared or QTI but if you look at the example code on the product page for the QTI sensors it suggests the result of the sensor is saved to a variable first and then used wih the Select Case method rather than reading direct, the infrared sensor is read direct using INL perhaps its a timing thing?
    edited 2012-04-18 08:28
    edited 2012-04-18 09:03
    Did you look at the example code on that product page? It suggests you use Select INL presuming you wired it as suggested to your robot.
    edited 2012-04-18 09:32
    The one parallax makes has 8 sensors I only have 5 on mine. Also INL selects inputs 0-7 I am using inputs 11-15. I think the suggestion from Phil will work i can test it today.
    This worked great we won 1st place thanks for the help. info here: http://www.tonytronix.com/myprojects/ee101bugproject.html
