Please help me with BS2 code for school robot project. Pic and code included!!!!
I am building a robot for school. I do not use basic stamp very often and I need help with a select...case statement. The select statement needs to select inputs 9-15. The code is very simple. I need a line to replace ( SELECT IN9-IN15 )
The code for the robot is in the link below.
code for robot.bs2
code for robot.bs2
This takes all 16 input bits as a word, and shifts it right by 9 positions, leaving bits 15..9 in positions 6..0.
But even then, I'm not sure that's what you want. Pins 15..9 represent seven pins, but your conditions use only six.
http://www.parallax.com/Store/Sensors/ColorLight/tabid/175/CategoryID/50/List/0/SortField/0/Level/a/ProductID/729/Default.aspx
