power supply filtering for 433mhz reciever
I'm using the MSR1 robot board with the propellor, and I'm having troubling when powering my 433mhz reciever (from Solarbotics http://www.solarbotics.com/product/30300/ ) from the MSR1 board,. The range on the reciever is significantly reduced, I've tried all kinds of filter caps, diodes and extra regulators, nothing works. I have the exact same poblem when using an RC reciever from a cheap RC car. I can only assume there is a noise produced from the propellor board that is causing the problem, sicne the modules work great when powered from an external source.
Any ideas ?
Any ideas ?
Cheers.
