Magnetic encoder
Dear all,
In thecourse of a project headed by the University of Economics and Business Vienna,we are looking for potential application fields of a magnetic encoder.
Basicallythe technology allows measuring the position of a magnet.
Can youimagine a field, where for instance one or several of the following problemsoccur;
· Positionshave to be measured contactless
· Extremeexternal conditions (dust, other magnetic fields, temperature, vibrations) haveto be passed over
· Maintenanceis difficult due to the high complexity of the final product/application
· Linear,rotating or three-dimensional positions have to be measured
· Thespace is limited and expensive
· Itis vivid to avoid/know about malfunctions of position tracking systems
· Easyimplementing and catch/use of the signal is necessary
· Anenergy effective solution is important.
Or do youknow somebody who could imagine that or needs that?
Thank youvery much!
Thank youvery much!
That's one type of magnetic encoder. There are others.
Here's a project I've have using a different type of magnetic encoder. I think this encoder better matches the traits Student was looking for.
http://forums.parallax.com/showthread.php?138736-Magnetic-Encoder-Project-(AS5055)
Have you also got any other ideas coming trough your mind spontaneously?
All the time. Do you know a way to keep them out?
Oh, you probably meant ideas about magnetic encoders. Once I finsh my taxes, I'll be working on making a PCB for the AS5055 encoders. I hope to sell several different PCB versions. I'll update the project thread when I have new information.
Good luck!
