In search of an opaque fabric that allows free air movement
idbruce
Hello Everyone
I need a fabric that is opaque but allows free movement of air. Is there any such fabric?
I want to surround a couple of heat lamps with a curtain of opaque fabric that will allow for heat dissipation. The heat lamps will be used in a photograghic darkroom environment.
Bruce
Bruce
Consider light baffles, which is how open-door darkrooms work (or worked; do people still use them??). It's basically a Z-bend opening, painted flat black. Light has a very hard time getting through. You don't need a lot of space if it's just air.
-- Gordon
As a separate side, I'm guessing this is so the darkroom can be heated? So as you know most photographic emulsions are sensitive to infrared. Infrared heat lamps, producing little or no visible light, will light-strike photographic film and papers. In darkrooms the heating must be indirect. Assuming it's for heating the room, you want some kind of forced-air heating from a different part of the building. You can pipe something in through a vent.
-- Gordon
@Gordon - I am only using the heat lamps to briefly heat up my chemicals to the proper temperature. I will be placing the heat lamps under the chemical trays.
@Erik - I need the element to quickly dissipate heat to prevent further heating of the chemicals. The heat lamps work very well.
I while back I had some infrared film I needed developed. The film could be developed with the same chemistry used for color slide film. The problem was the machines used to develop color slide film used an infrared light to count the sprocket holes. This infrared light didn't expose the normal color slide film but would expose the infrared film.
I ended up having to buy the chemicals and develop the film myself. It was actually kind of fun. I had never done the darkroom thing before.
So apparently not all film is sensitive to infrared light (not that Gordon had made such a claim).
Sorry for the sidetrack Bruce.
I used a large insulated cooler to help keep the water bath a constant temperature. The insulation really helped keep the temperature stable.
I'm wondering what kind of slide film this was. Ektachrome (E6) is somewhat sensitive to near infrared, though the cut off is at about 750-800nm as I recall. For many years Kodak sold a special "professional" color film with extended IR sensitivity. It was developed during WWII for aerial work. Was this the film you used? E6 process is about the only one you could do at home. Kodachrome is blind to infrared, but the K14 process is nearly impossible for mere humans to do, or at least that's what Kodak always said. In fact, I'm pretty sure no one does it now, or if they do, it's a small specialty lab that probably charges a fortune per foot. Do you recall the emulsion and process you used?
(It's too bad about Kodachrome ceasing production. I always thought it was the best color film ever, even ignoring Paul Simon's song. I have Kodachrome slides taken nearly 40 years ago that are as vibrant today as they were then. My Ekta slides are slowly weathering and losing color saturation.
-- Gordon
These are plastic trays, right? I guess that rules out an immersion heater. It might emit some IR, but you'd take it out of the soup and unplug it before processing any photos.
Not that I've ever done this myself, but I've seen guys heat up their developer in a microwave. They keep one in the darkroom, and remove the light. Being in California, I've never had to do that myself. I also always used liquid developer and fresh-batched each time, using warm water. For the stop and fixer I never cared what the temp was, though I imagine in places like Indiana where it actually snows now and then you'd want to avoid very cold liquids.
Ah, the memories of working in a chemical darkroom!
-- Gordon
Bruce
They wouldn't allow air flow, but perhaps they would solve the problem.
I can't believe anyone would go to the bother of sensitizing a photoresist to longer wavelengths than necessary - its complex dye based chemistry - I suspect the heat lamp is safe (but you can test this easily if worried). Usually violet/UV is needed for photoresists as only the weakest chemical bonds are affected by the red end of the spectrum. That's why we don't get sunburn under plain tungsten bulbs (tungsten-halogen emit a lot more blue/UV being run hotter).
I don't know where that came from, but okay. I am using DATAK Premier positive acting boards, which are exposed with a standard incandescent bulb. The heat lamps are also incandescent, but they are used for simply heating the etchant and developer. The developer must be between 100 and 110 degrees fahrenheit. I want to block the light from the heat lamps, just in case I need to warm up the developer or etchant while any protective coatings have been removed from the PCB material.
Please refer to the datasheet for further information.
http://www.philmore-datak.com/datakpos.html
@kwinn
Yes the objective is to eliminate temperature overshoot. As mentioned in another thread, and I probably should have posted it here as well, considering that the etchant and developer trays are considerably translucent, I must also block the light from going upward and shooting through the trays. I remember seeing this in an old photography book many years back, where they wrapped a light bulb in aluminum foil for some odd reason. I believe I will attempt this as a light shield. And I am well aware that it could considerably shorten the life of the bulb, if it does not burn out almost immediately. But hey, it is worth a try.
Bruce
Sometimes (depending on the thermal masses involved) you can measure the resistance of the heating element itself (while de-energized) to deduce the temperature at the interface
That was a pretty good idea, and it probably would have worked very well, however, at this point, my path is already well established. With the exception of any light remedy, I have already purchased the heat lamps, lamps sockets, building a platform, etc... The heat lamps work very well, in the fact that they do not overshoot the temperature. Simply turn the switch off and the temperature stops climbing. I have not tested the aluminum foil idea yet, but I think it will work.
Bruce
