Working on a VGA board for Quickstart (how much can one cram into 2"x3")
Oldbitcollector (Jeff)
Working on a new board kit for Quickstart:
I think this is my personal record for how much I can cram into a single 2"x3" board.
Features:
Audio R/L
VGA
PS2
Optional iR
Optional SD adapter
Wii
Anything anyone wants before this goes to production? (I think I have a half an inch left)
OBC
Features:
Audio R/L
VGA
PS2
Optional iR
Optional SD adapter
Wii
OBC
Real time clock?
OBC
Or, maybe you're going to use Vin... I guess that's 4.something volts...
Rayman: AFAIK I do not believe VGA requires 5V or 3V3.
I second the notion of adding an RCA jack, might as well hit all the points.
Sorry, my point is add a double stacked PS2 connector so you can have both keyboard and mouse. It takes up little extra room.
OBC
One of standards use spare pins as second PS2 port and with addition of split cable can use both ports on single PS2 connector.
Ps .. That don't interfere to use only one type of device on it Keyboard else Mouse
ps. shouldn't it be MMXII?
50 of Cluso's 4 pole, 3.5mm AV connectors are already on their way to you (posted last week).
These are really useful - through hole, cheap, solid, very compact, and take advantage of the 4 pole to 3xRCA cables widely available from ebay and elsewhere. I'll post some photos of them in use and perhaps Cluso can too
Looks good!
Richard
I have seen some wiring schemes that advocate that all of the central pins are grounded, along with pin 5, this would short out the supply. A lot of VGA leads do not have a pin in them, on Pin 9, probably out of safety.
Yes, I've been pondering a way to neatly combine multiple Quickstarts and/or boards like this..
Yeah, I keep forgetting to change that in my template.. Thanks
OBC
