Wall Following Examples (video and code)
Matt put out the call for some code samples to show off Parallax gear at the Expo. I'm planning on two wall following examples. The first uses a single Ping))) sensor with a BS2e controlling the CBA. It should run nearly unmodified on a Boe-bot once you change the stamp directive.
This sample follows a wall using arcs towards the wall and then a turn away from the wall. Like most of my good ideas it came from Robot Builders Bonanza
[video=youtube_share;xkYpWYhpIis]
Here's the code:
Attached for easy downloading:
SimpleWallFollow.bse
Here's the code:
' File...... SimpleWallFollowing.BSE
' Purpose... The robot follows a wall using a single ultrasonic sensor
' Author.... Martin Heermance
' E-mail.... mheermance@gmail.com
' Started... 2012 March 31st
' Updated... 2012 April st
' {$STAMP BS2e}
' {$PBASIC 2.5}
' Program Description
' This program can be used with a CBA or Boe-bot to follow a wall using only a
' single ultrasonic sensor. The basic concept used is from page 609 of "Robot
' Builder's Bonanza" by Gordon McComb
' Revision History
' Pin allocations. You might need to tweak the Ping))) pin.
Ping PIN 10 ' Pin for PING))) Sensor
RMotor PIN 12 ' Pin for right servo
LMotor PIN 13 ' Pin for left servo
' These values need tweaking for each robot's servos.
Speed075L CON 831 ' Fast left
Speed075R CON 658 ' Fast right
Speed050R CON 685 ' Slow right (to arc)
' These values control distance from the wall and sharpness of left turn
WallDistance CON 5
TurnCount CON 40
' Standard values from Ping))) example
Trigger CON 5 ' trigger pulse = 10 uS
Scale CON $200 ' raw x 2.00 = uS
RawToIn CON 889 ' 1 / 73.746 (with **)
RawToCm CON 2257 ' 1 / 29.034 (with **)
' Trigger Ping)))
IsHigh CON 1
IsLow CON 0
' This program is so simple it only needs a single variable to
' compute and test the distance to the wall.
X VAR Word
' Execution starts here
Main:
' Pause at start of program to let user set down robot.
PAUSE 1000
DO
GOSUB PingDistance
' If we're far enough from the wall the continue the arc.
IF (X > WallDistance) THEN
' Pulse once
PULSOUT RMotor, Speed050R
PULSOUT LMotor, Speed075L
PAUSE 15
ELSE
' Pulse turn count times to strongly turn away from the wall.
FOR X = 1 TO TurnCount
PULSOUT LMotor, Speed050R
PAUSE 15
NEXT
ENDIF
LOOP
' We'll never get here, but it's nice coding style.
END
' PingDistance - reads the distance at the current head angle.
' Inputs:
' Outputs:
' X - distance in inches.
PingDistance:
Ping = IsLow ' make trigger 0-1-0
PULSOUT Ping, Trigger ' activate sensor
PULSIN Ping, IsHigh, X ' measure echo pulse
X = X */ Scale ' convert to uS
X = X / 2 ' remove return trip
X = X ** RawToIn ' convert to inches
RETURN
[video=youtube_share;AQK6b2CNTrg]
Here's the code which is nearly identical to the previous sample except for a slightly altered main loop.
' ================================================== ============================ ' ' File...... AdvancedWallFollow.BSE ' Purpose... The robot follows a wall using an ultrasonic sensor and front bumper ' Author.... Martin Heermance ' E-mail.... mheermance@gmail.com ' Started... 2012 April 2nd ' Updated... 2012 April 3rd ' ' {$STAMP BS2e} ' {$PBASIC 2.5} ' ================================================== ============================ ' ------------------------------------------------------------------------------ ' Program Description ' ------------------------------------------------------------------------------ ' This program can be used with a CBA or Boe-bot to follow a wall using a Ping))) ' and a front bumper. The Ping))) points to the right and keeps the robot away ' from the wall while the bumper prevents front collisions the basic concept used ' is from page 608 of "Robot Builder's Bonanza" by Gordon McComb ' ------------------------------------------------------------------------------ ' Revision History ' ------------------------------------------------------------------------------ ' Pin allocations. You might need to tweak the Ping))) pin. Bumper PIN 9 ' Pin for front bumper (tactile or IR) Ping PIN 10 ' Pin for PING))) Sensor RMotor PIN 12 ' Pin for right servo LMotor PIN 13 ' Pin for left servo ' These values need tweaking for each robot's servos. Speed075L CON 831 ' Fast left Speed075R CON 658 ' Fast right Speed050R CON 685 ' Slow right (to arc) ' These values control distance from the wall and sharpness of left turn MinWallDist CON 6 MaxWallDist CON 8 TurnCount CON 40 ' Standard values from Ping))) example Trigger CON 5 ' trigger pulse = 10 uS Scale CON $200 ' raw x 2.00 = uS RawToIn CON 889 ' 1 / 73.746 (with **) RawToCm CON 2257 ' 1 / 29.034 (with **) ' Trigger Ping))) IsHigh CON 1 IsLow CON 0 ' This program is so simple it only needs a single variable to ' compute and test the distance to the wall. X VAR Word ' Execution starts here Main: ' Pause at start of program to let user set down robot. PAUSE 1000 DO ' If we are not close to a wall in front IF (Bumper = 1) THEN ' find out how close to a wall to our right. GOSUB PingDistance ' If we are too far from the wall pulse the left motor ' else if we are too close to the wall pulse only the right ' otherwise we are in the goldilocks zone and can do both IF (X > MaxWallDist) THEN PULSOUT LMotor, Speed075L ELSEIF (X < MinWallDist) THEN PULSOUT RMotor, Speed075R ELSE PULSOUT LMotor, Speed075L PULSOUT RMotor, Speed075R ENDIF PAUSE 15 ELSE ' We're about to smack into a wall so turn sharply left! FOR X = 1 TO TurnCount PULSOUT RMotor, Speed050R PULSOUT LMotor, Speed050R PAUSE 15 NEXT ENDIF LOOP ' We'll never get here, but it's nice coding style. END ' PingDistance - reads the distance at the current head angle. ' Inputs: ' Outputs: ' X - distance in inches. PingDistance: Ping = IsLow ' make trigger 0-1-0 PULSOUT Ping, Trigger ' activate sensor PULSIN Ping, IsHigh, X ' measure echo pulse X = X */ Scale ' convert to uS X = X / 2 ' remove return trip X = X ** RawToIn ' convert to inches RETURNAttached for easy downloading:
AdvancedWallFollow.bse
-MattG
I published the videos and code to the forum in the hopes that someone who goes might use them and have some fun with them. They should run on a Boe-bot with just a Ping))) as no servo is used, one of the whiskers would work as the bumper.
