LinuxCNC Users?
ctwardell
Anyone here have experience with LinuxCNC?
I'm looking at setting up a CNC Router using a Gecko G540 and I'm trying to decide if I want to use Mach3 (Windows XP or 32 bit Win7) vs. LinuxCNC.
C.W.
C.W.
If you ever should want to use servos, linuxcnc is capable, where mach3 is stepper only.
Try here ==> http://reprap.org/wiki/RepRap to get some background.
While 3D printer builders are using Linux software packages on LiveCD ==> The same software can be used with a lathe or a milling machine.
I'll try the LinuxCNC first.
It will be a few weeks before I can get all my hardware, I'm just doing as much planning ahead as possible.
C.W.
The old toshiba was one of the "desktop replacement" laptops that used a desktop chipset and cpu and the parallel port has EPP mode, so hopefully all of the warnings that laptops can't be used won't apply.
I'm still at least a few weeks away from actual hardware so I'll have to wait and see how it turns out.
C.W.
It will shoot up to around 50000ns if I launch a video on youtube, but that was the only way to make it go about 20000ns.
Safe to say I won't be watching any youtube video's while doing CNC work, so I'll use the 20000ns number.
It looks like I'll use a base period around 26uS with a dirhold of 2 since I'm going to use a Gecko G540.
C.W.
C.W.
