Slot game with parallal LCD?
Does the lcd slot game for BS2 work with a parallel lcd display? I don't have a serial lcd that it uses. I have a parallel lcd display and I dont know how to hook it up to the BS2 and write the program for it. I need diagrams to hook it up and the program to run it. Can someone please help me with this? Thank you very much for your help.
Here is the link to the serial lcd slot game,
http://forums.parallax.com/showthread.php?106697-LCD-Slot-Game-for-BS2
I would refer to the Stampworks manual for information on using the parallel LCD. It can be found here:
http://www.parallax.com/Portals/0/Downloads/docs/books/sw/Web-SW-v2.1.pdf
The code can be found here:
http://www.parallax.com/Store/Books/BASICStamp/tabid/168/CategoryID/42/List/0/Level/a/ProductID/144/Default.aspx?SortField=ProductName%2cProductName
Hope that helps to get started.
Jim
Experiment #11 shows you how to connect a parallel LCD to a BS2, (Page 75).
Try to run the parallel LCD first and get comfortable with the commands and go forth.
Jim
http://forums.parallax.com/showthrea...t-Game-for-BS2
