Slot game with parallal LCD? — Parallax Forums
dk3417dk3417 Posts: 5
edited 2012-04-03 18:23 in Robotics
Does the lcd slot game for BS2 work with a parallel lcd display? I don't have a serial lcd that it uses. I have a parallel lcd display and I dont know how to hook it up to the BS2 and write the program for it. I need diagrams to hook it up and the program to run it. Can someone please help me with this? Thank you very much for your help.
Here is the link to the serial lcd slot game,
http://forums.parallax.com/showthread.php?106697-LCD-Slot-Game-for-BS2
    edited 2012-03-29 09:07
    dk3417 wrote: »
    I would refer to the Stampworks manual for information on using the parallel LCD. It can be found here:
    http://www.parallax.com/Portals/0/Downloads/docs/books/sw/Web-SW-v2.1.pdf
    The code can be found here:
    http://www.parallax.com/Store/Books/BASICStamp/tabid/168/CategoryID/42/List/0/Level/a/ProductID/144/Default.aspx?SortField=ProductName%2cProductName
    Hope that helps to get started.
    Jim
  • dk3417dk3417 Posts: 5
    edited 2012-03-29 11:51
    Thank you Publison for your help. I checked out the links you provided and the it only shows how to make a slot game with LEDs but not with parallel lcd. I see the code and the hook up for the simple game which is a slot game but only with LEDs. Im not sure how to hook up the slot game with parallal LCD and write the code to it. Sorry for the trouble and thank you again for your help.
    edited 2012-03-29 11:59
    dk3417 wrote: »
    Experiment #11 shows you how to connect a parallel LCD to a BS2, (Page 75).
    Try to run the parallel LCD first and get comfortable with the commands and go forth.
    Jim
    edited 2012-03-29 16:48
    Thank you again Publison for you help. I understand how to hook up the parallal lcd to BS2 but I still dont know or understand how to write the code using parallal lcd to the slot game that is posted on the link below. I'm sorry, Im not being lazy about this, I just dont understand how to write the code. Thank you for your help.
    http://forums.parallax.com/showthrea...t-Game-for-BS2
    Can anyone please help me with post 5 on this thread? Thank you for your help.
