433MHz module: Translate basic to spin
Hello Guys!
Trying to control some wall-outlet relays, wich is cordless and works on the 433MHz band. I am completely new to the wireless stuff with propeller, and have never used it on another platform either.
I have found a protocol for the recievers, and also code that works with PIC (Basic, PBASIC?)
The protocol can be found following this link: http://svn.telldus.com/svn/rf_ctrl/nexa_2_6_driver/trunk/NexaProtocol.txt
And here is the Pbasic code:
It would be great if someone could help me translate this to spin, so that i have a test-code as a kickstart.
The code above does also use the parallax module, but way back when they came separated as sender and reciever.
Iam very excited to get started with this project, so any help will be greatly appreciated!
Thanks guys.
Daniel
DEFINE OSC 4
' Timing as described in NexaProtocol.txt
T CON 350 ' T = 350uS
T3 CON 1050 ' 3T
T32 CON 11200 ' 32T (Stop/Synch)
' Note we're using 1 VS X as shown in text
A1_ON CON %111000000000 ' 12-bit code for House/Unit A1 ON
A1_OFF CON %011000000000 ' 12-bit code for House/Unit A1 OFF
' ||||||||||||____ 4-bit House code
' ||||||||________ 4-bit Unit code
' ||||____________ 3-bit Unknown code
' |_______________ 1-bit Activation code 1=ON 0=OFF
D_PACKET VAR WORD ' Holds 12-bit data packet to send
INDEX VAR BYTE ' Data packet bit index pointer
LOOPS VAR BYTE ' Loop counter
TX VAR PORTB.0 ' Connects to RF transmitter data in
LOW TX ' TX output idles low for RF carrier OFF
Main:
D_PACKET = A1_ON
GOSUB Send
PAUSE 5000
D_PACKET = A1_OFF
GOSUB Send
PAUSE 5000
GOTO Main
Send:
FOR LOOPS = 1 TO 4 ' send each packet 4 times
FOR INDEX = 0 TO 11 ' sends 12 bits per pass LSB 1st
HIGH TX ' The 1st half of a 0 or X bit period is the
PAUSEUS T ' same so no need to repeat this sequence inside
LOW TX ' the IF block
PAUSEUS T3
IF D_PACKET.0[INDEX]=1 THEN
HIGH TX ' send a 1 bit (1=X here)
PAUSEUS T3
LOW TX
PAUSEUS T
ELSE
HIGH TX ' send a 0 bit
PAUSEUS T
LOW TX
PAUSEUS T3
ENDIF
NEXT INDEX ' loop until all 12-bits sent
' Start of Stop/Synch period after each 12-bit packet
HIGH TX
PAUSEUS T
LOW TX
PAUSEUS T32
' End of Stop/Synch period
NEXT LOOPS ' send 4 packets per pass
RETURN
END
Thanks guys.
Daniel
Some assistance please?
Alternatively, you could use PropBasic which has some similarities to your PICBasic and gets translated into Spin and Propeller Assembly Language.
Is there any direct equivalent for LOW / HIGH / PAUSE in spin? I think that i will manage the repeat loops, but i got stuck really at the basics on how the transmitter works. Often there are a object wich you can look at and with the help of that translate the code.
I have a bit experience of spin, but there are some methodes used with the transmitter that im not familliar with.
OUTA[x]~
DIRA[x]~~
HIGH x
OUTA[x]~~
DIRA[x]~~
PAUSE x
WAITCNT((CLKFREQ/1000)*x + CNT)
If you've already done the DIRA[x]~~ somewhere in your initialization code, you don't have to do it again. I put it here because, strictly speaking, the LOW and HIGH statements put the I/O pin into output mode.
That was just stupid of me to not think of the standard outa and dira.. Jesus, you shouldnt put down the coding project for more then a week
CON A1_ON = %111000000000 Var byte counter byte counter2 word D_PACKET PUB Main D_PACKET := A1_ON Repeat counter from 1 to 4 Repeat counter2 from 0 to 11 OUTA[1]~~ DIRA[1]~~ WAITCNT((CLKFREQ/1000)*350 + CNT) OUTA[1]~ DIRA[1]~~ OUTA[1]~~ DIRA[1]~~ WAITCNT((CLKFREQ/1000)*1050 + CNT) IF D_PACKET[counter2] := 1 OUTA[1]~~ DIRA[1]~~ WAITCNT((CLKFREQ/1000)*1050 + CNT) OUTA[1]~ DIRA[1]~~ WAITCNT((CLKFREQ/1000)*350 + CNT ELSE OUTA[1]~~ DIRA[1]~~ WAITCNT((CLKFREQ/1000)*350 + CNT) OUTA[1]~ DIRA[1]~~ WAITCNT((CLKFREQ/1000)*1050 + CNT) OUTA[1]~~ DIRA[1]~~ WAITCNT((CLKFREQ/1000)*350 + CNT) OUTA[1]~ DIRA[1]~~ WAITCNT((CLKFREQ/1000)*11200 + CNT)Is this somewere right or should i stop right now?
/Daniel
Thank you very much for your help. I did the changes you mentioned, but no luck. Dont get any response from the reciever.
I also tried to move down the repeat 0-11 but that dont change the result. Are you sure that it should only include the if-statements? Because to me it looks like it includes everything in the basic code.
Anyway, i tried it both ways no luck. Its hard to tell whats happening since its wireless
Any ideas?
Heres the code:
CON A1_ON = %111000000000 Pin = 24 Var byte counter byte counter2 word D_PACKET PUB Main OUTA[25]~~ DIRA[25]~~ D_PACKET := A1_ON Repeat counter from 1 to 4 Repeat counter2 from 0 to 11 OUTA[Pin]~~ DIRA[Pin]~~ WAITCNT((CLKFREQ/1000)*350 + CNT) OUTA[Pin]~ DIRA[Pin]~~ OUTA[Pin]~~ DIRA[Pin]~~ WAITCNT((CLKFREQ/1000)*1050 + CNT) IF (D_PACKET & |< counter2) <> 0 OUTA[Pin]~~ DIRA[Pin]~~ WAITCNT((CLKFREQ/1000)*1050 + CNT) OUTA[Pin]~ DIRA[Pin]~~ WAITCNT((CLKFREQ/1000)*350 + CNT) ELSE OUTA[Pin]~~ DIRA[Pin]~~ WAITCNT((CLKFREQ/1000)*350 + CNT) OUTA[Pin]~ DIRA[Pin]~~ WAITCNT((CLKFREQ/1000)*1050 + CNT) OUTA[Pin]~~ DIRA[Pin]~~ WAITCNT((CLKFREQ/1000)*350 + CNT) OUTA[Pin]~ DIRA[Pin]~~ WAITCNT((CLKFREQ/1000)*11200 + CNT)REPEAT ... <indent one level> REPEAT ... <indent two levels> 'There would be a NEXT here 'Not a part of the inner repeat 'There would be a next here 'Not a part of the outer repeat <more code not in the repeats>Having a hard time understanding what im doing wrong with the indention. I feel that every line after the IF block should be included in the loop for the total packets (4), and i think it is.
Its hard to describe, but please have a look.
So it works great now. And thanks for your clean code, some good pointers there!
Thank you very much for all your help.
