Will Prop BOE threads be on the Propeller Chip forum or elsewhere?
I've been watching the original 'Prop BOE being fabbed ' thread on the General Discussion forum but not much has been added in days.
As the title asks, is this the proper forum to watch for Prop BOE threads?
I suppose everyone who got their Prop BOE is busy working with theirs. So not much showing up yet. If this is the proper place to watch. Thanks for all replies.
I hadn't planned on documenting the upgrade by someone had asked about code for using the PropBOE with the BOE-Bot so I thought I'd share what I was doing in case it can help someone else.
I've seen BOE-Bots upgraded with a QuickStart board here in the Propeller forum so I don't think there's a hard and fast rule.
I'd think for general PropBOE stuff, the Propeller forum would be the right place to post.
I suppose I'm just a bit impatient. Though I'd think the Propeller forum would be the place for general Prop BOE threads. I understand using the robot forum for dedicated threads.
Just too early for much of anything to show up late (plus my impatience).
I plan to look into the voice synthesis (Gracey/ Pilgrim) first probably, while I figure out what's needed for the SD card use.
Propellers and robots are like [insert favorite two things that go together here]!
I'm running out of day. I wont start my PropBOE-Bot project until tomorrow. (I'm just about finished with my daisy-chained magnetic encoder project though.)
