Mechanical Flower runs too fast
This is a mechanical flower I made from a vegetable steamer, a parallax standard servo, and basic stamp. ( original designer Vern Graner )
can be seen at http://www.youtube.com/watch?v=5GTHwk1Wg7E
The project in mind is to use a ping sensor to activate the flower when closed and have LED's fade on and off with a heartbeat sound, the flower would then slowly open to bloom, and if a person stepped closer to the flower the ping sensor would activate the flower to close rapidly as if it was scared.
I have been able to operate the servo to open and close the flower ( vegetable steamer ) using standard code from the book. However I have not been able to get the flower to bloom and open slowly. I am looking for a very natural linear movement to bring my flower to life.
I am just a few weeks into Basic Stamp and this is my very first project. Any help would be most appreciated I have a great deal to learn,
Thanks Wayne
'{$STAMP BS2}
'{$PBASIC 2.5}
' program to open vegetable steamer (mechanical flower)
' original made by vern Graner
' servo connected to vss,vdd,and pin 0
' program will test servo for smooth opening of vegetable steamer
counter VAR Word
Flowerservo:
FOR counter = 1 TO 100 ' Loop for 2 seconds
PULSOUT 0, 1000 ' Servo counterclockwise
PAUSE 20
NEXT
PULSOUT 0, 500 ' Servo clockwise
PAUSE 20
NEXT
GOTO Flowerservo
Thanks Wayne
'{$STAMP BS2}
'{$PBASIC 2.5}
counter VAR Word
Flowerservo:
PAUSE 20
NEXT
PAUSE 20
NEXT
GOTO Flowerservo
That commands the servo to move all the way to one end, and
tells it to move all the way to the other end. The program does not have any in-between. What you need is a program that loops gradually from 500 to 1000 and back.
Parallax has a lot of educational material on using servos. Look at Andy's What is a Microcontroller to get started. Stamps in class Robotics.
Flowerservo:
FOR counter = 500 to 1000 step 2 ' adjust step value for speed
PULSOUT 0, counter
PAUSE 20
NEXT
FOR
[Now you insert code to make it go the other way]
NEXT
GOTO Flowerservo
And let's see a video!
Ken, your Flame Boe is diff-drive. It will toast (?) bread and deliver it. Close enough?
however, the movement is very choppy. I'm sure there is a slick way too give a smooth motion to the servo at slower speeds.
Any thoughts??
Thanks Wayne
Silky smooth action.
Spot on! A rookie mistake, but then I fully admitt to being a rookie.
I will post a video upon tweaking, hopefully after the weekend.
Thanks Wayne
Another thought: flowers tend to open & close by sunlight. You could have a photocell or phototransistor measure ambient light and use that to control the servo position. More light= more open. Then just using an overhead light with a dimmer would make the flower respond.
Well done Sir.
Steve
For reference, in case someone else searches for/finds this thread, here's the article on how to make the flowers:
http://www.notepad.org/articles/09-PowerFlowers.pdf
And a POC video of it in action:
http://youtu.be/Ydkk4-6FsWk
I attached three different versions of the source code to run the "Power Flower" as well. The BS1 does simple movement, the BS2 code uses a PING)) sensor to control the flower's motion and the BS2P code adds in control of a Rogue Robotics uMP3 player for sound. I cant for sure say that any of the code attached here is fully operational as I haven't reviewed it in years AND I believe I was iterating while developing and I don't think I ever got to a fully-working 1.0 on the BS2 or BS2P versions, but they should give you a good place to start. Hope this helps! :-D
