How about an Xbee board for QS?
Oldbitcollector (Jeff)
Started working on an QS Xbee board this morning.. Any feature you Xbee users would like to have?
(RevA, still sanding the edges....
OBC
OBC
OBC
Are ya’ll going to see these as blank boards, kits or both?
OBC
I would vote that the only time you should cover them is if you are reusing the pins they are attached to...
I'm not even sure it would still fit if we did that.. (ponders) Quickplayer is the only board slated to leave the touchbuttons open at this time. The servo/sensor board reuses them at the same positions.
OBC
Added servo/sensor style servo head.
Added connection point for microSD module
OBC
Couldn't the Xbee pins straddle the 40 pin connector? Or just reverse the 40 pin connector and have this board hang off the other way.
