How about an Xbee board for QS? — Parallax Forums
edited 2012-03-20 20:17 in Propeller 1
Started working on an QS Xbee board this morning.. Any feature you Xbee users would like to have?
(RevA, still sanding the edges.... ;) )
OBC
    edited 2012-03-20 10:19
    Full size SD socket.
    edited 2012-03-20 10:21
    Ouch! Settle for connections for a microSD module? ;)
    OBC
    edited 2012-03-20 10:25
    That would probably be acceptable.
    Are ya’ll going to see these as blank boards, kits or both?
    edited 2012-03-20 10:27
    Kits and blank boards upon demand..
    OBC
    edited 2012-03-20 14:20
    I would think the default for add on boards for Quickstarts should be that they don't cover the touch pads.
    I would vote that the only time you should cover them is if you are reusing the pins they are attached to...
    edited 2012-03-20 14:30
    @Roy
    I'm not even sure it would still fit if we did that.. (ponders) Quickplayer is the only board slated to leave the touchbuttons open at this time. The servo/sensor board reuses them at the same positions.
    OBC
    edited 2012-03-20 14:36
    I saw an Xbee board (Arduino shield) that supported 2 sockets... Curious, I thought until I saw the XBee footprint GPS module.
    edited 2012-03-20 16:53
    Ok, I think I'm getting closer...
    Added servo/sensor style servo head.
    Added connection point for microSD module
    OBC
    522 x 352 - 52K
    edited 2012-03-20 19:38
    Looks pretty nice. My only input is lame, but since it came to mind right away when I looked at the board, here it is... How about "quiXbee" instead of Quick Xbee?
    OBC,
    Couldn't the Xbee pins straddle the 40 pin connector? Or just reverse the 40 pin connector and have this board hang off the other way.
