Is there a limit to local longs? Strange behavior when I initialize some local longs. — Parallax Forums
turbosupraturbosupra Posts: 1,088
edited 2012-04-08 19:22 in Propeller 1
I have code with a bunch of local longs and I was testing to see if there was a limit to that.
When I do not comment out some of the initializations of the local longs, it appears that it hoses the repeat loop or maybe its timing.
When I comment out lines 189-197, the loop then works. Can anyone please explain why this is occurring for my own learning? I have pin 4 feeding pin 5 through a 100ohm resistor.
I can't attach the code to the forum because of the work firewall, but I can place it here. As a warning, the code is not cleaned up, things are commented out everywhere and normally I would try and clean it up a bit, but since this is such an oddball issue, I wanted to present it as is.
http://turbosupra.herobo.com/hosting/seq.zip
Thanks for reading.
«134
    edited 2012-03-14 07:33
    I haven't looked at the code yet, but do you know local longs need to be initialized to zero? They will start with some random number if not initialized. Only "result" starts out zero.
    edited 2012-03-14 07:35
    I'm getting a directory error when I try to extract the file.
    [SIZE=2][FONT=arial]Caution: Zip file comment truncated.
    Error: central directory not found.
    [/FONT][/SIZE]
  • MagIO2MagIO2 Posts: 2,243
    edited 2012-03-14 07:49
    Local longs are placed on the stack. So, if your stack is to small you should expect any kind of problems.
    Potentially there might also be a limit, as SPIN might use a byte offset for referencing local variables?! Not sure if I remember having heared something like that ;o)
    But in general it's a bad idea to code the propeller in the same way that you'd code a PC. Using to many local variables should simply be avoided.
    Can't access your ZIP file because of firewall settings here. Your hoster seems to be on our "NoNo"-list ;o)
    @Duane:
    Why do they have to be initialized to zero? What if zero does not make sense? Hopefully it can be reassigned to other values after initialization! ;oP
    edited 2012-03-14 07:54
    MagIO2 wrote: »
    I agree. They also don't show up as using the correct amount of memory when you press "F8".
  • idbruceidbruce Posts: 6,197
    I did not know that. Now I will have to recheck all my source for errors. What a bummer.
    edited 2012-03-14 08:02
    idbruce wrote: »
    I think that's common to most kind of stacks. It's only that other compilers will give you at least a warning that your variable has not been initialized. But I think this is a kind of a problem you would not be aware of even if it's describes somewhere in the manual. Some things you have to find out the hard way ;o)
    MagIO2 wrote: »
    @Duane:
    ;oP ;oP ;oP :smile:
    As you know, when the "not initilized" thing is a problem it's because the programmer is expecting the values to equal zero as global variables do.
    And yes, they can be initialized to anything you want (as long as it fits in a long). Germans!! :smile:
    I think I should be the only one allowed to purposefully misinterpret a post.
    edited 2012-03-14 08:08
    MagIO2
    Before making my post, I checked the Propeller Manual for PUB, and sure enough it stated that local variables had a random value.
    I normally initialize locals with values, but I may have taken it for granted in a few instances.
    Bruce
    edited 2012-03-14 08:14
    Duane
    I am not sure whether to thank you or curse you for that info. :)
    I think I will thank you.
    Bruce
  • turbosupraturbosupra Posts: 1,088
    edited 2012-03-14 08:29
    Eh ... I'm getting that error too now.
    Can I email it to you instead?
    Duane Degn wrote: »
    [/FONT][/SIZE]
    edited 2012-03-14 08:44
    turbosupra wrote: »
    You can and then I'll post it for you.
    My email is my first initial followed by my last name (five letters total so far) at abreviation for Micro Soft Network dot com.
    edited 2012-03-14 09:00
    Thanks everyone for the replies.
    I have increased the stack size of the other cog calls and because they weren't related to the main cog that didn't make a difference I guess, could it be local cog ram related?
    Also, this is in the main cog, so is there a way to hard code the amount of stack size for that?
  • RaymanRayman Posts: 16,229
    edited 2012-03-14 09:08
    I thought you figured out is was due to the local variables not being initialized...
    edited 2012-03-14 09:33
    turbosupra wrote: »
    The cog ram only has the Spin interpreter in it (unless you're running PASM code). The interpreter runs the code from hub and sets aside "stack" space for that cog in the hub (how could that be confusing?:smile:).
    edited 2012-03-14 09:48
    Hi Rayman,
    I was initializing all local variables originally. When I started to comment out some of those initializations in "main" before entering the repeat loop in "main", the code started working??? (backwards I know) I spent 6 hours messing around with it yesterday before I even got to that point of figuring that out. Since this is so bassackwards, I had to post about it and find out for my own sanity why this was happening and to avoid it.
    It may be because I have so many local variables and if there is a ceiling on that, I would just like to know?
    Rayman wrote: »
    edited 2012-03-14 09:49
    Ok, so it isn't cog ram :) ... could it be the initial cogs stack and that I've exceed the space for that with local variables?
    Did you receive my email? I guessed at the abbreviation as msn.com ?
    Duane Degn wrote: »
    edited 2012-03-14 09:55
    Ok, it sounds like you are out of stack space then. Your stack space is overlapping with your code. So, when you initialized it, you erased your code...
    edited 2012-03-14 10:08
    turbosupra wrote: »
    Sorry, day job got in the way.
    It will be a while before I can look at it.
    edited 2012-03-14 10:10
    Ok, that makes sense Rayman. Is there a way to manually set the main cog's stack, so that I can verify this before I covert the local variables to global variables?
    edited 2012-03-14 10:13
    No worries, just wanted to make sure I got the address correct.
    Thanks for attaching.
    Duane Degn wrote: »
    edited 2012-03-14 10:16
    I notice the Prop Tool doessn't like to display local variables it they extend past the intial screen.
    You might want to break them into several lines like this.
    PUB Main | localIndex, localPeriod, localCamPeriod, localCrankPeriod, timeStamp, {
             } currentCam, previousCam1, previousCam2, previousCam3, previousCam4, {
             } previousCam5, previousCam6, trigger1, trigger2, trigger3, currentCrank, {
             } previousCrank1, previousCrank2, previousCrank3, previousCrank4, {
             } previousCrank5, previousCrank6, previous5CrankAverage, elapsedTime, {
             } previousGap, currentGap, toothGap, toothGap1, toothGap2, toothGap3, {
             } toothGap4, toothGap5, toothGap6, previousToothGapAverage, toothGapRpm, {
             } crankToothRpm, previousNum1, previousNum2, previousNum3, previousNum4, {
             } previousNum5, previousNum6, current, previous5average, toothRpm
    edited 2012-03-14 10:24
    ^ Sweet, I didn't know you could do that, that is a great trick!
    The problem still exists after doing that, but that makes readability much much easier.
    edited 2012-03-14 11:01
    I just converted them all to global variables and had the same problem, then I converted them all back to local variables, still had the same problem ... commented some of the local variables out and it worked as expected?
    So although there may be a local variable limit based on the main cogs stack, I don't believe that was my issue after this testing procedures results
    The mystery continues ...
    edited 2012-03-14 11:08
    Let me ask some usual questions... How my free longs does the compiler say you have? Are you using Graphics.spin?
    edited 2012-03-14 11:22
    Hi,
    Program - 1023 longs
    Variable - 437 longs
    Stack/Free - 6728 longs
    I am not using graphics.spin
    I am using
    OBJ
      pst : "Parallax Serial Terminal"
      n : "Numbers"
      fcam : "jm_freqin"
      fcrank : "jm_freqin"
      f : "jm_freqin"
    Rayman wrote: »
    edited 2012-03-14 12:12
    You have plenty of free space then... I'd guess you have an error in your code and not a memory issue...
    Unless... Are you calling that routine with a lot of local vars recursively?
    edited 2012-03-14 12:31
    The main function running in the initial COG has the whole free HUB-RAM as stack-space. That's what this "Stack/Free - 6728 longs" tries to tell you ;o)
    If these things happen when commenting code you maybe have a problem with race conditions. For example several code-pieces running in different COGs use the same variable one has to write the other reads and does calculations with the read value. In these circumstances such problems might occur if the writer code did not run in time.
    It could also be related to the cognew which needs some time to start up the code.
    edited 2012-03-14 12:34
    Sometimes Stack/Free lies though... A lot of people start from Graphics_Demo, which uses a huge amount of undeclared HUB ram at the top of memory...
    edited 2012-03-14 12:40
    The psuedocode is
    Cog sends frequency out pin 4, jm_freqin reads frequency on pin 5, main cog polls jm_freqin.period method every so often for value and calculates data
    This could be the race condition you describe, but would it continually loop over and over, or would it only 0 out in some cases?
    Do I need to copy the value before performing calculations on it? How do you eliminate the possibility of a race condition?
    MagIO2 wrote: »
    edited 2012-03-14 15:03
    The things going on here are pretty complex. I've spotted the following:
    1. You seem to work with timings in several areas of your program. But on the other hand you are very generous with usage of PST. But PST has a buffer of 64 bytes. So, when you extend the number of characters send this will slow down your whole program and the conversions will be done in the COG calling the PST functions anyway. So, I'd suggest to think about a debugger/logger COG which runs independently.
    2. Chances are high, that these kind of if-statements don't do what you expect
    if(cnt > (timeStamp + (clkfreq/l_updateRateDenominator)))
    The problem is that the > operation is working with signed numbers. So, from $0000_0000 - $7fff_ffff it will see a positive number and from $ffff_ffff-$8000_0000 it will see negative numbers. In other words for the > operator $0000_0000 will be bigger than $8000_0000.
    If you work with a difference you don't have this problem:
    if((cnt-timeStamp) > (clkfreq/l_updateRateDenominator))
