Breadboard flat cable connector?
Erlend
Hi,
I'd like to have the Propeller on my computer desk, and the 'machinery' on the lab table. Therefore I have made an interface board at the 'machine' and run a ribbon cable to the Propeller (Professional Development Board) to avoid all the wire mess. That will also make it easier when the time comes to transfer from the development board to a permanent Propeller board, and that solution will also make it easer to switch between different development projects.
I have hit a problem though: Where can I find a flat cable-to-breadboard connector? -alternatively, how can I make it?
I find the connectors at the local shop.
The headers are RS-components 251-8339.
I tried also with flat cables, but they are dual row, so not so easy to use and you cannot use half of them, even if they are still handy when you need to carry a lot of signals.
Massimo
There is a company in Canada that has more. I don't remember their name but they advertise in Nuts and Volts
John Abshier
http://www.winford.com/products/cat_pbc.php
http://www.winford.com/products/cat_brk.php
http://www.ebay.com/itm/10-x-26-PIN-FLAT-RIBBON-CABLE-12-x-26-PIN-MALE-HEADER-/270653697734?pt=LH_DefaultDomain_0&hash=item3f0437aec6 (This one is a double wide. Use half, or double up on wires)
http://www.ebay.com/itm/3x-40-Pin-2-54-mm-Round-Male-Gold-Plated-Pin-Header-Single-Row-/170778955306?pt=LH_DefaultDomain_0&hash=item27c3380e2a
Nice solution Massimo. I had the same problem and ended up soldering two of the standard headers "back to back" (soldering the 3mm ends together) to give the same result. It is ugly but gives the correct 6mm pin lengths for breadboard and female IDC header.
It is possible to use the second half of the signals by adding a second female IDC header to the ribbon cable, a few mm away from the first one. That second connector plugs into the other side of the breadboard to give access to the second half of the signals.
To add to Massimo's suggestion, you can (usually) get long headers from SparkFun.
It helps when soldering wires to male headers if you use a strip of perf board to hold the pins in place. The third picture in post #46 of my Mecanum wheeled robot thread shows the radio receiver being plugged into the breadboard using male headers with wires soldered on (with strip of perf board). The perf board kept the pins from pulling out of the black plastic spacers.
The fourth (and 2nd) picture of the same post shows wires with female connectors being plugged into the breadboard with extra long male header pins.
(Make sure you all watch the latest Mecanum video in post #49!)
Erlend
