cog will not start
xanadu
I'm using a Prop Protoboard and I'm on Chapter 5 and 6 (PE book) cogs, objects, ect. Let me start by saying all example code works great. I have a top object calling three new cogs, making light blink passing variables, loads of fun.
The PE Book is great!
The problem I have is that my own program is not so great, and doesn't work. It seems as though there is no new cog launching. I have not yet grasped one hopefully minor aspect.
I only hear one beep, and only 'lcdmanager.lcdbottom' will run. I thought that cog0 keeps running and starting the other cogs, but it will not get past the first cog. The object the first cog loads runs great on its own, and also when loaded like this.
The other objects run great on their own as well when loaded into a single cog. However when I upload the code above it just stops and only runs the first cog.
The lcdmanager and lcdl2manager are separate cogs for separate lines of the LCD, could that be a problem even if they are not fighting over the pin?
OBJ
LCDManager : "LCDmanager"
LCDL2Manager : "LCDL2manager"
WatchDog : "WatchDog"
VAR
long stack[200]
CON
_clkmode = xtal1 + pll16x 'clkfreq 80 mHz
_xinfreq = 5_000_000
PUB Main
watchdog.beep
cognew(lcdmanager.lcdbottom, @stack[0])
'waitcnt(clkfreq / 2 + cnt)
watchdog.beep
cognew(lcdl2manager.start, @stack[50])
watchdog.beep
cognew(WatchDog.WatchD, @stack[100])
watchdog.beep
VAR long Stack[30], Stack1[30] PUB Main cognew(dosomthing,@stack) cognew(dosomthing,@stack1)Hope this helps,
Tyler
You have to call a method in that object that starts any cog it needs with its own methods.
I will try this.
Ah, it HAS to be in the same object. I knew it was something simple like that, but I thought I tried it both ways, must be a combination of the two things listed here. Thank you.
CON _clkmode = xtal1 + pll16x 'clkfreq 80 mHz _xinfreq = 5_000_000 VAR long stack1[100] long stack2[100] long stack3[100] OBJ ' is watchdog an object??? ' is lcdmanager an object??? ' is lcd12manager and object??? pst : "Parallax Serial Terminal" PUB Main | timeStamp, waitTime 'watchdog.beep cognew(lcd1, @stack1) ' call cog to start cognew(lcd2, @stack2) ' call cog to start cognew(lcd3, @stack3) ' call cog to start pst.Str(String("Starting ")) ' for sanitys sake when you are waiting for values to start appearing on the pst pst.Str(string(pst#NL)) ' a carriage return after printing something to the pst waitTime := (clkfreq/4) ' initialize local variable timeStamp := cnt ' sync variable to cnt repeat ' Do something here pst.Str(String("looping ")) pst.Str(string(pst#NL)) waitcnt(timeStamp += waitTime) PUB lcd1 | timeStamp, waitTime waitTime := (clkfreq/4) ' initialize local variable timeStamp := cnt ' sync variable to cnt repeat watchdog.beep waitcnt(timeStamp += waitTime) PUB lcd2| timeStamp, waitTime waitTime := (clkfreq/3) ' initialize local variable timeStamp := cnt ' sync variable to cnt repeat watchdog.beep waitcnt(timeStamp += waitTime) PUB lcd3| timeStamp, waitTime waitTime := (clkfreq/2) ' initialize local variable timeStamp := cnt ' sync variable to cnt repeat watchdog.beep waitcnt(timeStamp += waitTime)Call cognew from within the LCDManager object and not within your primary object
Thanks I am using separate object files to keep it easy to look at. I did this with the separate files, and it works well. With the exception that I do not think it's possible to control the LCD using two independent cogs for each line, at least for me right now anyway.
Thanks again everyone!!
@TylerSkyler:
What you say is wrong! Both COGNEW can use the same variable as a base address - no problem with that!
COGNEW( doSomething, @stack[0] ) is the same as COGNEW( doSomething, @stack + 0 )
COGNEW( doSomething, @stack[30] ) is the same as COGNEW( doSomething, @stack + 120 ) because of 30*size of long = 30*4 = 120
@turbosupra:
Your code also contains the bug which is using lcdmanager.lcdbottom. In other parts this is a valid function call specifying function lcdbuttom in object lcdmanager. But in a cognew it is really calling the function and the result of the function is passed to the cognew. Of course that's not what you want! In cognew only functions which are defined in the same spin file are allowed.
In general it is possible to control one piece of hardware from 2 COGs running the LCD driver, but some extra code is needed to hand over the PINs properly. So, usually it's a waste of resources! It's easier to call the LCD functions from 2 COGs syncing the functions for example via lock.
and I have corrected that in my code example.
