P8x32B
What would it cost to develop/release a Prop 1 with Port B available, in a QFP-80? No change to core, clocking, or ram. I wonder if, at this point, the remaining development effort on the Prop II might be serial enough to squeeze Prop1B development in parallel.
Why? P8x32A is a much lower-power processor than the Prop II, but can still benefit from more I/Os.
Has this been resolved?Paul Baker wrote: »It has been completed, but the LVS utility chokes on the design. Until we can resolve this issue, the P8X32B (Prop-1 w/ 64 I/O) will remain on the shelf.
I would bet that if Chip pursued the B rev, he'd rewrite the Prop 1 in Verilog and do a fresh layout. You could bet that he wouldn't leave the Prop 1B alone and most likely it would have hardware MUL, just like the book says.
The Prop 2 isn't 100% binary compatible (AFAIK) with the Prop 1, but the Prop 1B could easily replace the Prop 1A and be 100% code compatible.
For the 32 pin I/O packages, it just wouldn't have the Port B brought out to pins. This would permit Port B to be used like Port D is used in the Prop 2.
I wouldn't expect a Prop 1B anytime soon after the Prop 2, they would need to recover the dev costs of the Prop 2 and justify the development and mask for the Prop 1B.
When I win the lottery ...
