Learn how to solder @ the Parallax Expo! — Parallax Forums
Matt GillilandMatt Gilliland Posts: 1,406
edited 2012-03-06 15:19 in General Discussion
So, as part of our UPCOMING EXPO!!! , we'll be hosting a "learn how to solder workshop" (LHTSW), along with a bunch of other cool things.
The LHTSW is centered around Phil's charming little S2 Blinkie Badge design, and is FREE here at the EXPO...(go tell it on the mountains, and ev verryyywhere)...
So, my challenge to all of you Expert Solder Jocky's out there is to proof the instructions and/or give some suggestions before we make a bunch of these!
Oh, and don't be afraid to say: "Matt, you're perfect in everything you do..."
(why, oh why, do I open myself up to these kinds of things???)
-Matt
    edited 2012-03-05 12:18
    Looks cool. Are these going to end up at the other shows like the UPENE as well?
    Robert
    edited 2012-03-05 12:25
    You bet!
    We'll just have to be sure that we'd have a qualified instructor @ those venues - Look's like YOU'RE IT Robert :thumb:
    -Matt
    edited 2012-03-05 12:31
    You bet!
    I'll be glad to help teach anyone that wants to learn how to solder. I can explain how to solder both regular through hole components and even surface mount using ordinary tools.
    Robert
    edited 2012-03-05 12:34
    MattG: I appreciate the fact that you are opening yourself up to criticism, which is much better than exposure(!).
    Step 3 could probably be eliminated - it contains a little of Step 2 and 4 in the description. By the time I read from Step 2 to Step 4 I'd have fed a few feet of solder into the junction.
    The concept is clean, useful and practical. Black acrylic seems to be the right material, too.
  • W9GFOW9GFO Posts: 4,010
    edited 2012-03-05 12:39
    I think it would benefit from a clearer illustration - no offense intended to the artist. Something like this;
    And then a detail of proper solder joints;
    519 x 433 - 36K
    376 x 221 - 5K
    edited 2012-03-05 13:43
    Nice graphic, Matt! The only catch I see is that, on the S2 badge, the LED and switch get soldered from the side they're inserted into, so the leads can be trimmed flush with the top surface of the little bot. The pads on the top surface are minimally-sized so as not to intrude into the design too much and probably too small to solder easily. The exception, of course, is the battery holder, which gets soldered from the opposite side, so you don't have to heat up the entire piece of sheet metal.
    I would also recommend not putting the wheels on until last, just to avoid any accidental melting.
    edited 2012-03-05 13:55
    Matt, I echo Ken's suggestion of eliminating step 3, and a side-on example of at least one good joint. The deleted step 3 will make room for the added graphic(s).
    The illustration you show has the solder on the wrong side of the component lead. It suggests heating the solder directly at the tip. Rich's illustration is more like what I'd do.
    I think it's always a good idea to suggest a time limit, like no more than 4-5 seconds (or whatever). Beginners may not be aware the heat can't be applied indefinitely.
    Finally, I am ambivalent about putting this on plastic, near where soldering is going on. Acrylic doesn't release horrible stuff when melting, but melted plastic takes quite a while to cool off, and I'd be concerned about people getting burned simply because they're not thinking -- you'd be AMAZED how often I try to clean off the excess as I use a hot melt glue gun. Talk about dumb!
    It seems a bit unusual to use plastic for a solder station base. How about just making it a tent-fold sign or something? The base could be machine-cut aluminum. Maybe there's time to send it to an engraver to put the Parallax logo on it. Alternatively you could print this on paper or Mylar, and stick that on a metal base. Not a job for the in-house Laser Jocky, though.
    -- Gordon
  • SRLMSRLM Posts: 5,045
    edited 2012-03-05 14:25
    It's also not clear that steps 2-4 are supposed to be on the bottom of the PCB, since the last we heard was from step one which had directions for the top.
    Also, what is the bottom and what is the top?
    edited 2012-03-05 14:50
    Excellent input Forum-ites!...Suggestion box is open until tomorrow morning, at which time I shall incorporate worthy revisions, and then shall expose upon you a final *straw-man*, just before we go to press :thumb: err...I mean "impose"..
    -Matt
    edited 2012-03-05 15:44
    I thought it was engraved on anodized aluminum - which lasers engraves very nicely. I think the acrylic will get messed up before too long.
    edited 2012-03-05 17:35
    Loks like your aim is to put generic soldering instructions on the plate, and then I'm guessing you'll print up a sheet or tent or something with specific full-color instructions for the project at hand. That way you could use the same workstation plates next year with some other do-hickey. Is that correct? If so, you may not need to be too explicit about what's top or bottom, though I agree you might add to #2 "flip the board over" or some such.
    My *personal* preference would be to do these on brushed aluminum (you may not wish to use your in-house laser for this, depending on its optics, or use CerMark), and then wipe-on/wipe-off black lacquer into the engraving. Rich's idea is great, though I think anodized aluminum will show its age after repeated use, and then it's more expensive to re-anodize. You can more easily clean up brushed aluminum with steel wool or brush and some wheel cleaner from Pep Boys, and re-apply the lacquer.
    -- Gordon
  • Don MDon M Posts: 1,654
    edited 2012-03-05 18:12
    There should be some mention of keeping the tip clean. Most young kids I see seem to forget about doing that. That goes a long way towards making things easier to solder.
    edited 2012-03-05 18:16
    Any of you have a source recommendation for pre-anodized aluminum plates in various small sizes?
    edited 2012-03-05 18:21
    Only one thing really matters, and I'm happy to open this can of worms.
    Leaded solder or lead-free?
    Easy or green?
    I'm certain Parallax will go lead-free to be PC, although no one I know likes or uses that stuff. Not NASA, not no how!
    edited 2012-03-05 18:46
    Ken,
    You can get laserable anodized aluminum from BF Plastics:
    It comes in 12 x 24" sheets, with thicknesses ranging up to 0.050". You'd have to shear or bandsaw them to usable size, and maybe adhere them to something heavier.
    Here are some pre-cut sheets in smaller sizes:
    edited 2012-03-05 18:48
    Ken Gracey wrote: »
    Chewbarka.com
    They make (not re-sell) high quality anodized plates. What's really nice is that they anodize them after they are cut out so there are no sharp bare metal edges. They have many more sizes that what is listed on their website, you will probably need to call them to get the size you want.
    edited 2012-03-05 19:51
    Lead.
    It's orders of magnitude easier, and since the crowd will be complete newbies, they'll have a lot better chance of success. Plus, it's tough enough for a moderately experienced solder-jockey to get a joint that looks like the "good" example that'll be shown in the pics.
    I'm not PC.
    but, I'm not MAC either...
    -Matt
    edited 2012-03-05 21:21
    Ken Gracey wrote: »
    I've used Front Panel Express for a recent project and was really impressed with the results. They have free software to layout the design of the panel. If you want an odd shape panel you can do it but you need to draw that in a different cad package and import it. Other than that you can do quite a bit. Blind holes (Front or rear), threaded, engraving, color inlay, etc, Quality is top notch.
    You may be able to get material from them or have them do some of the fabrication.
    http://www.frontpanelexpress.com/
    Robert
  • Tony B.Tony B. Posts: 356
    edited 2012-03-06 05:49
    Matt,
    I'd love to read what you wrote, but I don't see a link to the document. What am I missing?
    Tony
    edited 2012-03-06 13:13
    Tony B. wrote: »
    Matt,
    Tony
    No document, just the picture in the first post.
  • RDL2004RDL2004 Posts: 2,554
    It had me baffled too. It was kind of hard to see, probably just my monitor settings.
    388 x 386 - 40K
