Midi ic?
__red__
Greetings,
Anyone know of an IC or module that can take MIDI events and produce audio? I guess I'm looking for the IC that lives in a billion cheap piano keyboards.
I would be feeding this from the propeller so UART would be the interface that I'd prefer.
Red
Red
See if the VS1053B does what you want. I have not looked at this in detail for midi or general midi output. I use it for MP3 decoding and playback from a USB drive and like it. T
Have you tried the P8X32A!
Unless you can easily work with surface mount you'll probably want a breakout board with the chip already on it. I keep trying to get Parallax interested in making one, but in the meantime, there's always SparkFun. Look at their Musical Instrument Shield. You can use it as a simple breakout if you don't have an Arduino. Connect 5V, ground, Rx, and Reset.
There's also the Fluxamasynth, a shield using an Atmel MIDI synthesizer. It appears a bit more robust than the VS1053 in the effects department. This board is about $10 more than SparkFun's, though.
-- Gordon
