Midi ic? — Parallax Forums
Midi ic?
__red____red__ Posts: 470
edited 2012-02-29 12:25 in General Discussion
Greetings,
Anyone know of an IC or module that can take MIDI events and produce audio? I guess I'm looking for the IC that lives in a billion cheap piano keyboards.
I would be feeding this from the propeller so UART would be the interface that I'd prefer.
Red
  • T ChapT Chap Posts: 4,223
    edited 2012-02-29 07:40
    http://www.sparkfun.com/products/8892
    See if the VS1053B does what you want. I have not looked at this in detail for midi or general midi output. I use it for MP3 decoding and playback from a USB drive and like it. T
  • Ahle2Ahle2 Posts: 1,179
    edited 2012-02-29 09:40
    "Anyone know of an IC or module that can take MIDI events and produce audio?"
    Have you tried the P8X32A!
    edited 2012-02-29 11:35
    Yes, the VS1053 is one of the go-to chips for this. I use it a lot for MIDI. It's quite adaptable, and the serial-in protocol is MIDI standard, allowing you to use it with any MIDI controller -- or, of course, product your own controller using a Propeller or whatever.
    Unless you can easily work with surface mount you'll probably want a breakout board with the chip already on it. I keep trying to get Parallax interested in making one, but in the meantime, there's always SparkFun. Look at their Musical Instrument Shield. You can use it as a simple breakout if you don't have an Arduino. Connect 5V, ground, Rx, and Reset.
    There's also the Fluxamasynth, a shield using an Atmel MIDI synthesizer. It appears a bit more robust than the VS1053 in the effects department. This board is about $10 more than SparkFun's, though.
    -- Gordon
  • CircuitsoftCircuitsoft Posts: 1,166
    Looks like the SAM2195 isn't Atmel anymore.
