Schematic Sanity Check please...
This is the most complex schematic and PCB that I have ever designed.
Could people please give it a sanity check? It's designed around the MAX7219.
Advice welcome.
Red
Advice welcome.
Red
See how nice I made my triple 595 led board.
That is nice. Wow.
Unfortunately I do need the connections to be in order so I do have to have crossings. Interestingly Erik above said that I didn't have to use such large traces so I guess I could have passed between the 0.1" pitch headers instead of being silly with vias.
As requested...schematic.pdf
So would you normally remove ground plane islands from your circuit or try and connect them via the top layer?
Yes.
My main concern is that this is the first time I've ever designed a schematic from a datasheet. The boards are ordered so they're set in stone (err, copper).
As a "fail-safe" I printed a "business card" on the back so if they all fail at least they'll have a second lease on life :-)
Note the red circles, for example, those traces could be partially router to the top side to allow the ground plane to connect.
