Schematic Sanity Check please... — Parallax Forums
__red____red__ Posts: 470
edited 2012-02-23 03:09 in General Discussion
This is the most complex schematic and PCB that I have ever designed.
Could people please give it a sanity check? It's designed around the MAX7219.
Advice welcome.
Red
  • MacTuxLinMacTuxLin Posts: 821
    edited 2012-02-21 18:53
    If it is not a hassle, could you upload a .PDF or image instead? I don't have Diptrace installed.
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2012-02-22 04:36
    Its not the best idea to have ground plane islands, I see you have connected them with traces under the IC's. I would do it a little different. 30 mil tracks are larger than you need for driving leds.
  • tonyp12tonyp12 Posts: 1,951
    edited 2012-02-22 17:40
    Is there a reson that so many traces have to cross path?, is it's becuase the item you connect have it so and can not be changed?
    See how nice I made my triple 595 led board.
    491 x 111 - 11K
  • __red____red__ Posts: 470
    edited 2012-02-22 18:26
    tonyp12 wrote: »
    That is nice. Wow.
    Unfortunately I do need the connections to be in order so I do have to have crossings. Interestingly Erik above said that I didn't have to use such large traces so I guess I could have passed between the 0.1" pitch headers instead of being silly with vias.
    edited 2012-02-22 20:56
    MacTuxLin wrote: »
    As requested...schematic.pdf
    edited 2012-02-22 20:58
    So would you normally remove ground plane islands from your circuit or try and connect them via the top layer?
    edited 2012-02-22 22:25
    __red__ wrote: »
    I assume those caps are non-polarized...
    403 x 142 - 5K
    edited 2012-02-22 23:43
    MacTuxLin wrote: »
    Yes.
    My main concern is that this is the first time I've ever designed a schematic from a datasheet. The boards are ordered so they're set in stone (err, copper).
    As a "fail-safe" I printed a "business card" on the back so if they all fail at least they'll have a second lease on life :-)
    It takes some careful routing to remove islands, sometimes you have to run some traces on the top side to allow a decent cross section.
    Note the red circles, for example, those traces could be partially router to the top side to allow the ground plane to connect.
    1024 x 592 - 157K
