USB port on proto board - or is it my lap-top? — Parallax Forums
TappermanTapperman Posts: 321
edited 2012-02-23 00:38 in Propeller 1
Dallas Semiconductor DS-1620 thermal probe. Comments may not be current in program.
When I run the attached program, it keeps rebooting on my proto board. Now here’s the problem, it only just started doing this two days ago! I’ve been using in for some time now, with no issue. Then suddenly, its behavior changed.
Nothing has changed on the laptop, no software was installed or removed. But I thought the problem might be related to the USB chip on the proto board, soI tried it out on a new proto board. And I get the same result.
I should mention, I’m running the parallax data gathering macro that runs on excel. Which uses an OCX or something, correct?
... Tim
