USB port on proto board - or is it my lap-top?
Tapperman
Dallas Semiconductor DS-1620 thermal probe. Comments may not be current in program.
When I run the attached program, it keeps rebooting on my proto board. Now heres the problem, it only just started doing this two days ago! Ive been using in for some time now, with no issue. Then suddenly, its behavior changed.
Nothing has changed on the laptop, no software was installed or removed. But I thought the problem might be related to the USB chip on the proto board, soI tried it out on a new proto board. And I get the same result.
I should mention, Im running the parallax data gathering macro that runs on excel. Which uses an OCX or something, correct?
... Tim
... Tim
Thanks for the help! And yes 'data gathering' mode. The funny part is, it actually worked for several nights collecting data! I'll just re-write it using a high eeprom flag, and hope that cures it! These well known issues ... where do you find them?
... Tim
http://forums.parallax.com/showthread.php?129627-Is-there-a-way-to-query-for-presence-of-serial-connection-to-enable-disable-PST
/Niclas
