Servo Catapult Accuracy
I was so impressed by the "Positive Pressure Gripper" thread & video at http://forums.parallax.com/showthread.php?137966-Robotic-arm-uses-quot-positive-pressure-quot-to-work-its-magic&p=1074926#post1074926 that I wanted to see if my simple robot arm could shoot any baskets. But after rethinking the G-forces and resulting abuse involved, I left my 6-servo arm alone and made a single-servo catapult-style shooting arm test jig to see how repeatable a servo "sling" could be. Pretty dang repeatable. Futaba S3004 analog servo running on a 7.4V lithium battery and my fave, a BS2 HW board. The arm is 14" long, lightweight aluminum tube.
Next step: Auto-loader.
I build bots wit a group of kids , they will like a catapult.
Please some details and close pictures .
7,4 volts for a Futaba S3004 is it not a bit high ?
Jean Paul
Multiple servos, multiple arms, multiple auto-loaders.......
Very Cool! That's impressive.
Servos sure make easy for a uC to interact with the physical world.
Maybe this is where your (erco's) arm could help out?
I agree, an auto-loader would be cool. So too would a turntable with two or three cups, and the chance that a ball won't make it in.
-- Gordon
The consistency is surprisingly good, but the servo power will probably degrade over time as the motor brushes & commutator wear. Such is life in the big city, but it's fun for now. Too bad the scale is so big. I'd like to nail everything down to a board. Like a 4x8 board!
I have some. Perhaps it's my turn.
Well, anyway,... all I have is Parallax's standard servo, and it's not transiting anywhere near fast enough. Dang.
Major depression sets in.
Wish I hadn't torn down my SpinStamp stepper circuit.
Plop.
@PJ: As I said, I had to use a long arm and 7.4 volts to the servo to achieve that moderate toss. I'm not above trying 8 or 9 volts either. Tune for minimum magic smoke...
I still have one unopened box of "snappers".
From the box:
"D.O.T. Class C Explosive" - Talk to me.
"A novel trick item." - Whatever
"Recommended for outdoor fun." - Oh, stop already.
"Please do not put in mouth." - I'm way ahead of you.
now how can we incorporate these into the ELEV-8 air show?
Catapults tossing snappers could add a whole new sense of urgency for the pilots in the baseball dropping contest...
-Tommy
Well, that was in the "good old days" when they made things more substantial.
From this ME's POV, uC's make it easy for servos to interact with the physical world!
Well, PJ anyhoo... just roughed out for Expo. Auto loader, IR remote, multiple target zones, etc. Might not have laser & sonar seeking yet for Expo, depends on timing...
For the ultimate in simplicity, how about nothing, which the current servo requires?
Additionally, the servo's trajectory (range of arcs) is all programmable using pulsouts.
It works amazingly well over a variety of trajectories. The only change I'd consider making would be to increase the range by using a torsion spring. The servo would preload the torsion spring to a programmable amount, and then the lightweight catapult arm would be unlatched by a tiny release solenoid.
