fun with conductive ink!
I got a conductive ink PEN....... what to do?
well i painted some lines on glass and presto secure glass plug a MCU to monitor the continuity of the conductive ink line some one breacks the glass there you go!
any one else got a good ideal? i am using an old computer for this untill my new props come.
if you want to do what i did
pick your fav micro write code to monitor a pin
the input pin should be tied high and then conected to one end of the line the other end to ground
connect a buzzer or speaker too and make a real alarm
i know simple......... but fun!
Draw some lines on a hard floor to use a spill/leak detector?
Use a coin cell and LED to make greeting card that lights up without having any wires running through/across the card? You might be able to make a switch the turns on when the card is closed but I think switching on the LED when the card is opened would be a trick. Maybe a "pop-up" style mechanism that slides one piece of paper over another as the card is opened. The sliding piece of paper would have a conductive ink section that would close the circuit on the rest of the card.
I think I have a conductive pen somewhere. I'll need to dig it out and see if it still works.
On the same lines :- use them as capacitive plate switches
and use an electromagnet to energize it
and as it moves around, it comes into proximity
with a Hall Effect sensor which detects positions
and can switch on and off certain tasks. You could
etch a Hall disk to play musical notes. Unlike
optical CDs, the disk would be less sensitive
to dirt or scratches.
