433 RF transceiver operation below 32 degrees?
Anyone know why a Parallax 433mhz RF transceiver is only rated to operate in 32 degrees F minimum? I want to use mine for something outside, but live in a cold climate where temperatures will often fall below 32. Will low temperatures just affect the transceiver's performance, or will the low temperature actually damage it? Thanks in advance!
I have been using the transmitter in temperatures below to minus 30 C without problem. The problem was the BS2pe that went into sleep at -28C. I used a little 12V light bulb to heat the BS later. The transmitter has never needed any external heating but a heat resistor or light bulb would be a good idea just in case.
