Running Propeller off LiPo or LiIon?
I am thinking of running a propeller directly off a lipo or liion cell...no voltage regulator.
What are the ramifications of this? I imagine the propeller will use a bit more power when running at say... 4.2V instead of the specified 3.3V.
I'm not sure what the VIN max of the propeller is. I know that 5V will do bad things to the prop, but I don't know about this middle ground.
Please educate me.
Thank you.
Please educate me.
Thank you.
Why not use an LDO regulator? I don't think you'd save any power by not using a regulator...
I can state with absolute certainty that 9 Volts is too high ...
That reg certainly seems to have sorted out the current spike that a lot of the older ones had.
I can just about hold focus on that size of packaging too!
