"Clipped sine wave" TCXO as Propeller clock source
I've discovered only recently[*] that temperature-compensated crystal oscillators are available from the usual distributors for quite affordable prices. Most offer a so called clipped sine wave output with a guaranteed 0.8 Volt peak-to-peak amplitude connected to a 10kOhm // 10pF load.
The one I've ordered is from the Taitien TX series (second from top on http://www.taitien.com.tw/en/products_vctcxo.aspx).
With only the 10M//15p oscilloscope probe as load I observe a 0 to 1.1V signal on the TCXO output. So I guess the options for connecting this signal to the Propellers XIN pin are:
The manufacturers appnote on this topic is available here
Thank you in advance for your opinion/thoughts/experiences on this.
[*]Last year I bought a few small OCXOs via eBay. Compared to the TCXOs in questions those are designed for 5V and want approx. 65mA at room temperature. They need a much larger footprint on the pcb (not to mention the height..). But they are quite a bit more stable, both with temperature and aging if they datasheet is correct.
- Direct connection.
Won't work - 1.1V is most certainly too low for the logic threshold. - Coupling capacitor to remove the existing DC-Bias, followed by a voltage divider to set a new bias voltage near the Propellers Vcc/2.
Might work with careful bias point selection. - Coupling capacitor to remove the existing DC-Bias, use XTAL3 clock mode instead of XINPUT.
Could this work? Would only need one additional capacitor. - Use an inverter with a feedback resistor (self biasing) between the TCXO and propeller to provide a full amplitude clock signal with sharp edges.
Will work, needs an additional IC (single gate).
What price are these ?
I'd use that one, ie configure as a Xtal osc (biased inverter) and AC couple. Much more tolerant than resistor biasing, and Diode kludges, and will give a close to 50% clock input.
Another alternative would be a Dual-Supply Logic Translator, where you can adjust the IP side Vcc to set Duty cycle.
Or, you could look at a device like a 74HC6323 (SO8), which would allow a more common 10MHz TXCO, to feed a 5MHz Prop CLK out
I will try #3 on a spare board and see how it works out.
EDIT: Works just fine with #3 from first post and a 26MHz TCXO, PLL disabled of course.
