Cheap Serial LCDs — Parallax Forums
Cheap Serial LCDs
ercoerco Posts: 20,263
edited 2012-02-14 05:38 in General Discussion
  • JLockeJLocke Posts: 354
    edited 2012-02-14 02:49
    Looks like two 16x2 LCDs on the same board. Think I'll stick with a more traditional-type display. But I guess someone could have a use for the dual displays.
    It seems that using a Parallel LCD with a serial-to-parallel shift register chip can accommodate most situations where you need a serial LCD, but have a Parallel.
    embedded-lab.com/blog/?p=30
    Of course if you require the RS-232 levels, it is a much bigger issue.
