Increasing the distance between the ultrasonic sensor and. B.Stamp 2 ( But How ? )
hi
How can I Increase the distance between the ultrasonic sensor and the B.Stamp 2 ?
I will need about 100 feet of cable between the ultrasonic sensor and the B.Stamp 2
Do you know how can I do this ?
All suggestions are welcome.
Thanks, Mark
Thanks, Mark
Do you know if it is possible to reduce baud rates to 2400 instaed 9600 is better for long distances.
And do you know if a very thick wire is better instead of a narrow wire.
Or a wire with some kind of mesh could reduce interference ?
Thanks , Mark
Q1: I do not know.
Q2: A thicker wire will have a lower impedance than a thinner one.
Q3: A shielded cable would reduce interference, but some interference will always get through. (Chaos-Making a New Science by James Gleick)
--Rich
