Basic Stamp Question - Button Switch Circuit
Ref: page 139 of the Basic Stamp 2.2 manual. (http://www.parallax.com/Portals/0/Downloads/docs/prod/stamps/web-BSM-v2.2.pdf)
My question is about the switch circuit illustrations shown for use with the Button command. Does the I/O pin sink any current or does it only see the voltage that is present on the other side of the 220 ohm resistor? I expect it is the latter, as I don't know how it would work otherwise, but wanted to make sure I understand how the Stamp pins handle this. More importantly, I know the BS2 is limited to 50mA per 8 I/O pins, and that would limit the number of switches if each was sinking 23 mA. If someone can confirm this for me, I'd appreciate it. Thanks.
