Arm Wrist/Gripper Uses 9-gram servos — Parallax Forums
ercoerco Posts: 20,263
edited 2012-05-22 11:28 in Robotics
Mini 6-axis arm underway. Here's what I did tonight:
    edited 2012-01-24 06:09
    Sweet. Once I finish the mini-CNC I may circle back to my arm.
    edited 2012-01-27 00:43
    Today, I control the Cosmic Cube. Tomorrow... the world!
    edited 2012-01-27 06:19
    That gripper is working well. As I've said before my gripper stinks and has been the Achilles heel of my arm. My current thinking is the electromagnet picking up foam blocks with a washer glued to the top, but that is backed up behind CNC machine completion.
    Are you planning to do inverse kinematic transforms using a co-processor, canned motion scripts, or something else?
    edited 2012-01-27 08:14
    Grippers are finnicky, they're a whole science to themselves.
    No co-processor for me. That's cheatin'!
    For now, canned scripts, ultimately will use an IR teach pendant. Will try several different processors on this arm. BS2 HW board shown here.
  • ajwardajward Posts: 1,130
    edited 2012-01-27 16:46
    Sweet! Keep us up to date!
  • WhitWhit Posts: 4,191
    edited 2012-01-27 19:09
    Very nice work erco!
    So are roboticists...
    edited 2012-02-09 01:59
    First test. Looks like it has some potential! Kinda looks like a snake the way it moves. Yeah, I meant to do that...
    edited 2012-02-09 04:43
    Looking good. I like the base you have it on, those lines should really help you with the motion scripts.
    edited 2012-02-09 08:35
    That's $30 worth of servos and $10 worth of superglue & kicker. Poor man's "rapid prototyping" !
    One more late night and it's headed for an article in the next ROBOT magazine.
    edited 2012-02-09 20:33
    Erco...
    What kind of wire are you using in your linkage?
    Amanda
    edited 2012-02-09 21:28
    I guess you mean the bellcrank wire linkage in the gripper, as opposed to the electrical wire running through all the joints...
    PAPER CLIPS, of course! Plentiful, strong and easy to bend. Large wire paperclips.
  • CowboyCoderCowboyCoder Posts: 33
    edited 2012-02-09 21:52
    Nice work erco! Do you have any pics for those of us so far away from humanity that we are stuck on dial choke choke up?
    edited 2012-02-10 06:34
    Arrrr... forgot all about those. Even have a box of them sitting on my desk! :-|
    Have to sort through mine tho'. Some of them have little crimp marks so you can't bend them without breaking. What a lame idea =that= was!
    edited 2012-02-10 08:37
    Ted: Sure, here's a pic for you to hold you over until your next Robot magazine arrives! :) It's a quickie slam build, CA gluing servo to servo and aluminum tube. It's beauty lies in its simplicity & low cost. The whole robot costs ~$50 if you know where the deals are! At that price, it's not currently controlled by a Parallax product, but it will be at some point. :)
    816 x 612 - 59K
    edited 2012-02-12 16:18
    This thing is a hoot! More accurate than I dare hoped, with light loads anyway. Everybody oughtta build one of these, they're lots of fun to play with. Er, I mean, scientifically calibrate and empirically determine the coefficients of dynamic performance. :)
    edited 2012-02-13 12:46
    Pretty quiet around here. I guess me and my ugly duckling arm will go home.
  • XNORXNOR Posts: 74
    edited 2012-02-14 15:03
    I think it's great. Form follows function. I would love to see plans/instructions on the gripper design.
    edited 2012-02-15 05:30
    I'm still in awe....it can spell too!! :lol:
    edited 2012-02-15 09:19
    erco,
    Took your suggestion, ordered some 9 gram servos from ebay.
    Looks like a fun build.
    Keep us posted on what issue of SERVO your article appears in, I’ll pick up a copy.
    edited 2012-02-15 15:15
    It will be in the next issue of ROBOT magazine (May/June). Just sent to the publisher, probably on the newsstand in 4-6 weeks.
    TTYTT, I used three generic 9-gram servos costing ~$2 each from Ebay China, but since the servos are glued directly together, I would recommend using HXT-900 servos from Hobby King. They are barely more expensive at $2.69, but supposedly much more robust. A better gamble for a one-time installation.
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=662
    Good prices, bad response time. Allow 3+ WEEKS for delivery. Sometimes it takes a week to get an "order acknowledged and sent to warehouse" verification!
    edited 2012-02-15 17:33
    ROBOT got it, I'll check the news stands in that time frame.
    I took a gamble and got the ones below. 4 @ $10.80 delivered
    http://www.ebay.com/itm/4x-TP-SG90-mini-servo-800g-Torque-Helicopter-Cat-Boat-S-/120651545973
    edited 2012-02-17 07:00
    Nice arm erco.
    It's fun to see it stack those blocks. You could add some blocks with numbers and have it keep track of the time.
    We were given a little calendar that uses two blocks for the date. All the possible days of the month could be made with two blocks with numbers on their sides. It does require the "6" of some dates be used as a "9" for other dates.
    I just noticed the HXT900 servos are back in stock. I should be posting pictures soon of my recent 18-servo project (using these small servos).
    edited 2012-02-17 08:47
    Duane Degn wrote: »
    Hexapod, I'm guessing? Burning thru your supply of popsicle sticks with wild abandon? 3 of ten fingers still superglued together? :)
    edited 2012-02-17 09:17
    You're right about the hexapod.
    My superglue was all dried up so I'm using Polymorph. I'm also using some M2 nuts and bolts to hold some things together.
    None of my 9.9 fingers (table saw claimed 0.1 of them) are currently glued together (which isn't alway the case). ( I've also had my eye glued shut before. I now always wear safety glasses when using CA.)
    I have been burning through my popsicle sticks but my box of 1000 (aka craft sticks) looks like it still has over 900 left so I should have enough to finsish this bot.
    edited 2012-02-17 10:17
    I sure hope there's no Altoids tin in your design. :)
    edited 2012-02-17 10:58
    That's a great idea! An Altoids tin is just the right size for a chassis.:smile:
    Or, not. The main body will likely be one popsicle stick wide and two popsicle sticks long. I had initially tried to make it just one popsicle stick long but then the legs were too close together to move. Not that they are moving at all now. Who would have thought getting 18 servos to move in a coordinated manner would be a trick?
    edited 2012-02-17 11:57
    Duane Degn wrote: »
    OR, simply use one servo and one motor for all 6 legs. :)
    http://www.youtube.com/watch?v=LsTKAtBBkfU
    edited 2012-02-23 13:20
    Duane Degn wrote: »
    I just got my first HXT servos from Hobby King yesterday (took a MONTH to get here, sheesh). Supposedly stronger gears than my generic HK $2 servos. They feel smoother. Best thing is that they rotate ~190 degrees, whereas my HK servos are more like 170 degrees. Worth the extra dollar, but waiting that month was painful.
    edited 2012-03-04 17:29
    Today's upgrade, now that the magazine is out.
    edited 2012-03-04 17:57
    That is a great demo. I especially like the keyboard to select the letter.
