Quad Half Bridge driver board — Parallax Forums
pedwardpedward Posts: 1,642
edited 2012-03-02 07:12 in Propeller 1
I've been working on some stepper research and came up with a board design for a Quad Half Bridge.
Specs:
8A continuous rating per half bridge
.024 ohm 2W current sense chip resistor
48A 8.4 milliohm N-channet mosfets with ultra low 4-8nC gate charge
30V max voltage
IR2302 high side N-channel half bridge driver, runs off +5v
Phoenix contact 5.08mm MKDS series terminal blocks
To answer Phil's question first, the ground pour is only connected to the motor ground, but the logic and motor ground are connected by a single thin trace.
The board is rendered in the DorkbotPDX colors, probably how I'm going to have them fabbed.
