Proto Board Servo's Question
Tapperman
I can't seem to find any documentation regarding the servo's that attach to the protoboard. I have soldered the headers to the protoboard and installed the jumper ... but I can't find any documentation regarding the servo's on the protoboard. I'm sure I've just over looked something?
... Tim
... Tim
Some else asked about the same thing last week.
Let use know if the other thread doesn't answer your questions.
Hey thanks ... I searched for the problem, but didn't come up with any hits!
... Tim
The short answer is you have to run a wire from the pin you want to use to the servo header signal pin.
