need a Prop Plug bulk head connector
hi, I am working on a PROP project that requires an enclosure. What I am looking for is a bulk head connector to recieve the Prop Plug then I would hard wire the connector to the PCB. I searched the net with no luck.
Does anyone know where to buy such a connector ? thanks for helping - Dave
[h=1]Connector Unshrouded Header 36 Position 2.54mm Solder Right Angle Thru-Hole[/h]or
similar http://www.jameco.com/Jameco/catalogs/c121/P64.pdf
Just solder some the headers (above) to a small piece of generic PCB board and mount it in the enclosure using standoffs so that the pins are recessed in a rectangular opening.
You can insert the prop plug into the opening...
I have an eclosure I've done this on. I'll take a picture and post it in a bit.
I didn't use expoxy myself. I use ShapeLock (aka Polymorph) to hold the header in place.
Ron,
I don't suppose you have a picture of one of your enclosures where you did this? I'd love to see how it looks.
I was looking through your projects and your enclosures all look so nice.
Care to share any tricks of the trade?
How do you cut the holes in your enclosures?
Duane,
Generally I try to make a template using graph paper and a digital caliper.
I use a Dremel tool with abrasive cutting discs. A Dremel flexible shaft makes it much easier. I always cut small and then do a lot of tedious filing/sanding or Xacto knife shaving.
For LCD displays, I like to use the Lexan bezels sold at Scott Edwards. They are pricey but really look nice. http://www.seetron.com/mounting.html
I would love a CNC machine or even a precise miniature table saw but I have to make do with a drill press and hand tools.
use a standard female DB9 on the outside of your project. Wire the bottom 4 pins (pins 5-9 on the connector) in order of the pins on the prop plug to the correct pins of your PCB (Vss, RES, Tx, Rx). For added protection, using a hammer to lightly tap a pin into the hole, then on the back side solder a pin into #3 of the DB-9, so it acts like a key. This eliminates the possibility of someone down the line mistaking it for an RS232 standard com port, and the possibility that the mistake will fry your mainboard.
Next, take your male DB-9, and solder a 4x1 header with 0.5 spacing. Break, cut, or mill the 3rd DB-9 pin off of this so it will accept the keyway. Then all you have to do is plug your PropPlug into the 4 pin header. With some tricky carving, it is even possible to get the prop plug to fit into a standard 2 piece backshell for it, with the USB port sticking out where the wire hole is. then you have a nifty little adapter that will allow you to (re)program your firmware later down the road. Making this a standard connection for your projects means you can re-use the prop plug.
And, it keeps your project looking professional, instead of having a rough hole cut in your case with a header poking out.
I was afraid that was going to be your secret.
Thanks.
http://forums.parallax.com/showthread.php?130611-Looking-for-Panel-Mount-Prop-Plug-Connection-Ideas
http://forums.parallax.com/showthread.php?109517-Suggestions-needed-for-interfacing-a-Prop-Plug-to-a-metal-enclosure
