need a Prop Plug bulk head connector — Parallax Forums
camelot2camelot2 Posts: 54
edited 2012-02-03 15:51 in Propeller 1
hi, I am working on a PROP project that requires an enclosure. What I am looking for is a bulk head connector to recieve the Prop Plug then I would hard wire the connector to the PCB. I searched the net with no luck.
Does anyone know where to buy such a connector ? thanks for helping - Dave
  • camelot2camelot2 Posts: 54
    edited 2012-02-03 08:29
    what I really need is a connector which attaches to the enclosure, then on the outside I just plug in the Prop Plug and on the inside I hard wire 4 wires to the PCB. Any thoughts how this can be done ?
    edited 2012-02-03 08:37
    camelot2 wrote: »
    Just solder some the headers (above) to a small piece of generic PCB board and mount it in the enclosure using standoffs so that the pins are recessed in a rectangular opening.
    You can insert the prop plug into the opening...
    edited 2012-02-03 08:50
    thanks for the reply Ron, that sounds like a good idea and cheap. I will try it out - Dave
    edited 2012-02-03 09:00
    When I asked just about this same question a while back, someone suggested using a female header epoxied to the inside of the enclosure and using a male header with the Prop Plug. I liked this idea myself.
    I have an eclosure I've done this on. I'll take a picture and post it in a bit.
    edited 2012-02-03 09:43
    I'm using two Propellers in this project so the header is 2x4. I haven't make a Prop Plug with male headers; I just use long female headers to connect the Prop Plug (homemade version) to the header in the enclosure.
    I didn't use expoxy myself. I use ShapeLock (aka Polymorph) to hold the header in place.
    462 x 488 - 438K
    533 x 360 - 340K
    431 x 373 - 255K
    668 x 516 - 634K
    edited 2012-02-03 09:58
    Ron,
    I don't suppose you have a picture of one of your enclosures where you did this? I'd love to see how it looks.
    I was looking through your projects and your enclosures all look so nice.
    Care to share any tricks of the trade?
    How do you cut the holes in your enclosures?
    edited 2012-02-03 10:16
    Duane Degn wrote: »
    Ron,
    Duane,
    Generally I try to make a template using graph paper and a digital caliper.
    I use a Dremel tool with abrasive cutting discs. A Dremel flexible shaft makes it much easier. I always cut small and then do a lot of tedious filing/sanding or Xacto knife shaving.
    For LCD displays, I like to use the Lexan bezels sold at Scott Edwards. They are pricey but really look nice. http://www.seetron.com/mounting.html
    I would love a CNC machine or even a precise miniature table saw but I have to make do with a drill press and hand tools.
  • SarielSariel Posts: 182
    edited 2012-02-03 10:18
    I have done this a few times in the past....
    use a standard female DB9 on the outside of your project. Wire the bottom 4 pins (pins 5-9 on the connector) in order of the pins on the prop plug to the correct pins of your PCB (Vss, RES, Tx, Rx). For added protection, using a hammer to lightly tap a pin into the hole, then on the back side solder a pin into #3 of the DB-9, so it acts like a key. This eliminates the possibility of someone down the line mistaking it for an RS232 standard com port, and the possibility that the mistake will fry your mainboard.
    Next, take your male DB-9, and solder a 4x1 header with 0.5 spacing. Break, cut, or mill the 3rd DB-9 pin off of this so it will accept the keyway. Then all you have to do is plug your PropPlug into the 4 pin header. With some tricky carving, it is even possible to get the prop plug to fit into a standard 2 piece backshell for it, with the USB port sticking out where the wire hole is. then you have a nifty little adapter that will allow you to (re)program your firmware later down the road. Making this a standard connection for your projects means you can re-use the prop plug.
    And, it keeps your project looking professional, instead of having a rough hole cut in your case with a header poking out.
    edited 2012-02-03 10:41
    I was afraid that was going to be your secret.
    Thanks.
    edited 2012-02-03 15:07
    The trick with the male pin header for the transition between the two female connectors is to put the header on a piece of hard timber and then lightly press the plastic holding piece down until the pins are equal in length on both sides of the plastic spacer. Works a treat.
    Here are a couple of photos, with the header pins on a circuit board inside the ABS box. The opening is machined with the box held on a cross-slide in drill press (not NC, old fashioned) , with a 1/8" router bit. The photo on the right is a similar setup for an SD card slot.
    432 x 288 - 28K
    432 x 537 - 54K
    493 x 366 - 74K
