Eddie Movements
Hey,
It seems like when Eddie is travelling forward, it's ramping up and down speed is smooth according to the acceleration value set to 07h.
But when Eddie is travelling backwards, the ramping down speed is not as smooth and it seems to stop suddenly.
Also if a STOP 10 command is issued when Eddie is travelling backwards, it can cause sudden very strong jerks.
Stopping while travelling forward does not have this issue.
Currently using Firmware v1.1
NickL
This will speed up the firmware development.
Normally the controllers on the wheels control the speed and direction of the motor as their output is normally sent to the HB-25 motor drivers. However in this case Parallax seems to only use the motor controllers on the wheels to determine distance and direction as they do not control the HB-25 motor drivers on the EDDIE Propeller Controller Board. I have a Propeller board interfaced to the controllers on the wheels and the output of those controllers interfaced to the HB-25s as is normally done. I have no problem controlling the motors in this configuration. Either backwards or forwards. Parallax definitely needs to correct the V 1.1 code to work correctly with their interface.
Just a thought.
TCIII
