Scribbler 2 hacker port; beginner
Hello,
I'm somewhat new to Parallax products and circuitry in general, but I do have a bit of experience in low-level software. I recently bought the Scribbler 2 to try out the Propeller, and it works very well. Now I would like to extend it using the hacker ports, but I'm not exactly sure how. I have this small motor that I would like to connect for testing, and if I connect it to the high voltage ports and ground it works well but not with the Propeller ports 0 - 5 when I turn them to high. I'm pretty sure I'm doing something wrong, can anyone explain it to me?
Thanks.
Thanks.
Edit: Welcome to the Parallax forums!
So two more questions:
Would the power form the propeller port be good enough if it didn't have a translator?
And what is the voltage from the hacker port?
Edit: the hacker port is 5 volts.
Do you have any LEDs? You could use LEDs with 330 Ohm resistors to test the hacker port's signal lines.
In my opinion, the S2 would be a much better robot if Parallax hadn't used the level translators. The translators interfere with the Propeller receiving some signals (such as the pulse from the Ping sensor).
The hacker port has three rows of pins. The bottom row (toward the back of the robot) are the signal pins. The middle row is 5V for driving small loads such as a servo. The top row is ground.
You should be able to access the power from the batteries directly by connecting a jumper near the serial port. I believe the jumper allows access to the battery power from the serial port. You could use this power source for driving larger loads.
-Tommy
