Quickstart version of PTP2 (3.5" touchscreen adapter) — Parallax Forums
RaymanRayman Posts: 16,456
edited 2012-05-30 14:13 in Propeller 1
The original PTP and PTP2 are for Propeller Platform.
Since Quickstart came out, I thought I'd make a PTP2 "mezzanine" for Quickstart.
The prototype works just fine:
The good thing about it is that it just plugs in and runs off of USB power.
So, it's easy to use and it's a very small package.
Perhaps one not so good thing is that it covers up all the I/O.
So, if you wanted to connect more things to it, it might be tough...
If anybody sees a way to make it better, please let me know.
I'm kinda on the fence about getting a batch made...
    edited 2012-01-16 15:24
    Another very cool board.
    Rayman wrote: »
    We could still run wires to the holes in front of the QuickStart's header right?
    Another option would be to add headers to the bottom of the QuickStart board and use a "basement" board to access additional I/O pins.
  • RaymanRayman Posts: 16,456
    edited 2012-01-16 16:07
    Thanks Duane. That's a very good point. Somehow I forgot about those extra holes...
    Coming in from the bottom still gives access to those, as you said.
    edited 2012-01-17 06:28
    Well, we sold this first one already, so maybe there is some demand...
    edited 2012-01-17 07:02
    Yes, another cool board! Well done!
    Any chance of adding an SD card and a LIPO power connection?
    With those additions, you'd have a pretty powerful little handheld sandwich.
  • pgbpsupgbpsu Posts: 460
    edited 2012-01-17 08:21
    Rayman-
    Would it also be possible to extend the footprint of the PTP2 mezzanine board so an additional downward facing 40-pin connector could be placed just outside the current one, wired in parallel? One would be used to plug into the Quickstart board. The second would allow access to all P-pins. I suppose it could be populated with an upward or downward facing header provided it sat far enough out from the touch screen to be accessible. Just a thought.
    Nice board and I really like this move to USB power.
    Did actually decide to sell these boards... So they are up for sale now here: http://www.rayslogic.com/Propeller/Products/PTP2/PTP2.htm
    pgbpsu, sorry, I guess I didn't reply back... Maybe I should have made the board bigger, but decided to keep the same design (same size as Quickstart) rather than take a chance on doing something wrong for the production run.
    mindrobots, see now I forgot to reply to you too... There is the second 40-pin connector... Maybe somebody can make something that connects to that...
    Or, one can maybe use stackable headers to put another board on somehow...
