Logic timing in PASM — Parallax Forums
MacTuxLinMacTuxLin Posts: 821
edited 2012-01-13 21:12 in Propeller 1
My first dig at PASM due to requirement. The logic diagram is also attached. May I request anyone to see if I've made any stupid mistakes? Thanks.
Jon, if you see this, may I check with you, how do you set a constant number of #24 to account for the setup/call/return in the pauseus routine? Is it a common known value or how should I calculate it?
' Write Byte to device
owwrbyte                rdlong  value, iodata                   ' get byte from
                        mov     bitcount, #8                    ' 8 bit counter
wrloop                  shr     value, #1               wc
                        mov     usecs, #26
        if_c            add     usecs, #9
        if_c            jmp     #:wronebit                      ' Logic 1 = low
                        or      dira, owmask                    ' Logic 0 = low
                        call    #pause434us
                        andn    dira, owmask                   ' Logic 0 = high
                        call    #pause434us
:wronebit               or      dira, owmask                   ' Logic 0 & 1 = low
                        call    #pause434us
                        andn    dira, owmask                   ' High till end Time_bit
                        call    #pauseus
                        djnz    bitcount, #wrloop
                        wrlong  ZERO, cmdsel
                        jmp     #owmain
' Pause in 4.34 microseconds
pause434us              mov     ustimer, cnt                    ' sync with system clock
                        sub     ustimer, #24                    ' <-- account for setup/call/return, value is commonly known?
                        add     ustimer, four34ustix            ' set timer for 4.29 us (remove 0.05 us for waitcnt)
                        waitcnt ustimer, four34ustix            ' wait and reload
pause434us_ret          ret
' Pause in 1 microseconds
pauseus                 mov     ustimer, cnt                    ' sync with system clock
                        sub     ustimer, #20                    ' account for setup/call/return
                        add     ustimer, oneustix               ' set timer for 1 us
usloop                  waitcnt ustimer, oneustix               ' wait and reload
                        djnz    usecs, #usloop                  ' update delay count
pauseus_ret             ret
  • Mark_TMark_T Posts: 1,981
    edited 2012-01-13 02:48
    The propeller manual gives cycle timings for every instruction. Most instructions are 4 cycles. Exceptions are conditional jumps that are _not_ taken (8 cycles), waits and hub instructions (which synchronize with the hub on a 16-cycle round-robin basis).
  • MagIO2MagIO2 Posts: 2,243
    edited 2012-01-13 02:55
    You only have 2 fixed times, so I have to say that I don't see a need for flexible timing functions!
    			mov     waittime, cnt                   ' this is used in all waitcnt
                            add     waittime, 4_34delay
            if_nc           mov     usecs, shortdelay
            if_c            mov     usecs, longdelay
                            waitcnt waittime,4_34delay
                            waitcnt waittime,usecs
                            wrlong  ZERO, cmdsel
                            jmp     #owmain
    4_34delay               long    constant( ((CLKFREQ / 1_000 ) *  4_340) / 1_000 )
    shortdelay              long    constant( ((CLKFREQ / 1_000 ) * 25_980) / 1_000 )
    longdelay               long    constant( ((CLKFREQ / 1_000 ) * 34_660) / 1_000 )
    The calculation of the delays is like that because we are in integer domain. So, only dividing by 1_000 (=> shift to ms) in the first step keeps as much digits as possible whilst avoiding an overflow.
    ( CLKFREQ/1_000_000 * time is the general formula, but does not work good in integer domain. )
    This is the quick and dirty implementation, because in the long periode you add some time to the waitcnt for the code which runs until setting the next start-bit. But this should be deviation which does not make problems because we talk about <1us.
    If you want it completely perfect you can simply move the waitcnt usecs to another position and do it after all the code that gets the next bit.
    edited 2012-01-13 03:08
    Let's have another version (the delay subroutines do get in the way):
    rd[COLOR="orange"]byte[/COLOR]  value, iodata
                    mov     bitcount, #8
                    mov     cnt, cnt
                    mov     cnt, #9
    :loop           waitcnt cnt, [COLOR="blue"]short[/COLOR]
                    or      dira, owmask            ' low
                    andn    dira, owmask            ' high
                    shr     value, #1 wc            ' sample bit
                    muxnc   dira, owmask            ' low/high
                    waitcnt cnt, [COLOR="blue"]tail[/COLOR]
                    djnz    bitcount, #:loop
                    waitcnt cnt, #0                 ' guarantee last bit tail
                    wrlong  ZERO, cmdsel
                    jmp     #owmain
    short           long    347                     '  4.3375us @80MHz
    tail            long    2079                    ' 25.9875us
    To answer your question, the logic is OK. But as mentioned earlier, having dedicated delay code is overkill here. I removed an earlier comment as for some unexplained reason I had [thread=137206]a 0.1us delay[/thread] stuck in my head (too much alcohol maybe).
  • MacTuxLinMacTuxLin Posts: 821
    edited 2012-01-13 05:19
    Mark_T wrote: »
    Thanks Mark. So that's why its #24.
    edited 2012-01-13 05:26
    MagIO2 wrote: »
    [/code]
    Got it. Yes, I understand now. I'll implement delay calculation in this manner instead. Thank you MagIO2.
    edited 2012-01-13 06:16
    kuroneko wrote: »
    rd[COLOR=orange]byte[/COLOR]  value, iodata
                    mov     bitcount, #8
                    mov     cnt, cnt
                    mov     cnt, #9
    :loop           waitcnt cnt, [COLOR=blue]short[/COLOR]
                    waitcnt cnt, [COLOR=blue]tail[/COLOR]
                    wrlong  ZERO, cmdsel
                    jmp     #owmain
    Hey Marko! Thank you but it took me quite a while to understand ... sorry I have some questions:
    1. what does this means? I thought cnt is a register & cannot be used as a destination operand?
                    mov     cnt, cnt
                    mov     cnt, #9
    2. I like this!
    3. I'm a little confused, when its logic 0:
                    waitcnt cnt, [COLOR=blue]tail                          '<---- should the "waitcnt cnt, short" be here and ...? [/COLOR]
                    djnz    bitcount, #:loop [COLOR=#0000cd]              '<---- should the "waitcnt cnt, tail" be here before the djnz ?[/COLOR]
    4. I don't see how adding #0 to waitcnt means the tail is selected?
    0.1 usecs ... :lol: yeah, sorry, when I started seriously digging into PASM a few days ago, I was abs(lost) but things are starting to fall into place and the more I dig the more I like PASM! :smile:
    edited 2012-01-13 06:38
    When you use a read-only register like CNT in the destination field of an instruction like "MOV cnt, cnt", the "shadow RAM" location is used instead. In "MOV cnt, cnt" both cases are used. The actual CNT register is used for the source (of the data) and that's written to the shadow RAM location. In "ADD cnt, #9", the shadow RAM location is used and the constant 9 is added to it. In "WAITCNT cnt, short", the saved time in cnt is used for the time to wait until and the contents of short is added to the shadow RAM location after the wait is satisfied.
    Note "shadow RAM' is the actual RAM location that exists at the cog memory address used for some register. There's a RAM location corresponding to each of the Prop's I/O registers, but they're only accessible under some circumstances because the I/O register takes precedence when processing the source field of an instruction. When processing the destination field of an instruction, the shadow RAM location is always written. The I/O register is read when it's read-write, but the I/O register is not used when it's read-only. Instruction fetches always use the shadow RAM.
    edited 2012-01-13 09:48
    Thank you Mike. This "shadow" coding is like ninja moves. There's one more thing I'd like to confirm:
    Mike Green wrote: »
    So, does it explains the reason why Marko added #9 to factor in the cycle time for the previous MOV & this WAITCNT instructions so that the pulse duration is as accurate as possible?
    Mike Green wrote: »
    So, is this shadow RAM something like cache? I won't get such jems from the manual .... :tongue:
    edited 2012-01-13 10:01
    Its just the cog RAM. The last 16 words of the 512 word cog RAM share addresses with the 16 cog special registers (including cnt, ina, outa etc etc). Whether the RAM or the register is accessed depends on the type of access and the register involved. This can be a little confusing.
    And don't confuse cog RAM with hub RAM (hub RAM is byte-addressed, cog RAM is long-addressed)
    The manual does describe this as far as I remember (particularly in the descriptions of the various special registers).
    edited 2012-01-13 15:58
    MacTuxLin wrote: »
                    mov     cnt, cnt
                    mov     cnt, #9
    Imagine cnt (dst slot) is called temp. That's probably less confusing. But using the shadow seems more convenient. As for adding #9, the code sequence is capture cnt, add adjustment, minimal waitcnt. This specific value makes sure we spent as little time as possible in those 3 instructions (14), i.e. the waitcnt exits immediately. Using 8 (adjustment) cycles forces us to wait for a roll-over.
    MacTuxLin wrote: »
    In PASM waitcnt works slightly different (compared to SPIN that is). It waits for a match on its dst value, then adds src for the next match.
    • we start with a minimal waitcnt (ref) and set the line low (advance by short)
    • the next waitcnt will block until ref+short then we drive the line high (advance by short)
    • next point is ref+2*short, we drive the line according to bit value (high/low) and advance by short
    • next point is ref+3*short, we drive the line high and advance by tail
    • if we loop the waitcnt at the beginning will make sure we wait until ref+3*short+tail
    • if we exit we explicitly wait for the final target to be reached, we don't have to advance here
    :loop           waitcnt cnt[COLOR="orange"]{ref or ref+3*short+tail}[/COLOR], short
                    or      dira, owmask
                    waitcnt cnt[COLOR="orange"]{ref+short}[/COLOR], short
                    andn    dira, owmask
                    shr     value, #1 wc
                    waitcnt cnt[COLOR="orange"]{ref+2*short}[/COLOR], short
                    muxnc   dira, owmask
                    waitcnt cnt[COLOR="orange"]{ref+3*short}[/COLOR], tail
                    andn    dira, owmask
                    waitcnt cnt[COLOR="orange"]{ref+3*short+tail}[/COLOR], #0
    HTH
    edited 2012-01-13 21:11
    kuroneko wrote: »
    :loop           waitcnt cnt[COLOR=orange]{ref or ref+3*short+tail}[/COLOR], short
                    or      dira, owmask
                    waitcnt cnt[COLOR=orange]{ref+short}[/COLOR], short
                    andn    dira, owmask
                    shr     value, #1 wc
                    waitcnt cnt[COLOR=orange]{ref+2*short}[/COLOR], short
                    muxnc   dira, owmask
                    waitcnt cnt[COLOR=orange]{ref+3*short}[/COLOR], tail
                    andn    dira, owmask
                    waitcnt cnt[COLOR=orange]{ref+3*short+tail}[/COLOR], #0
    HTH
    After going thru your code for long while (including talking to myself), I finally understood =D !!! Thank you very much Marko! Yes, its a very different mind-set for me. Have a good weekend All.
    Mark_T wrote: »
    Thank you Mark.
