Logic timing in PASM
MacTuxLin
My first dig at PASM due to requirement. The logic diagram is also attached. May I request anyone to see if I've made any stupid mistakes? Thanks.
Jon, if you see this, may I check with you, how do you set a constant number of #24 to account for the setup/call/return in the pauseus routine? Is it a common known value or how should I calculate it?
' Write Byte to device
owwrbyte rdlong value, iodata ' get byte from
mov bitcount, #8 ' 8 bit counter
wrloop shr value, #1 wc
mov usecs, #26
if_c add usecs, #9
if_c jmp #:wronebit ' Logic 1 = low
or dira, owmask ' Logic 0 = low
call #pause434us
andn dira, owmask ' Logic 0 = high
call #pause434us
:wronebit or dira, owmask ' Logic 0 & 1 = low
call #pause434us
andn dira, owmask ' High till end Time_bit
call #pauseus
djnz bitcount, #wrloop
wrlong ZERO, cmdsel
jmp #owmain
' Pause in 4.34 microseconds
pause434us mov ustimer, cnt ' sync with system clock
sub ustimer, #24 ' <-- account for setup/call/return, value is commonly known?
add ustimer, four34ustix ' set timer for 4.29 us (remove 0.05 us for waitcnt)
waitcnt ustimer, four34ustix ' wait and reload
pause434us_ret ret
' Pause in 1 microseconds
pauseus mov ustimer, cnt ' sync with system clock
sub ustimer, #20 ' account for setup/call/return
add ustimer, oneustix ' set timer for 1 us
usloop waitcnt ustimer, oneustix ' wait and reload
djnz usecs, #usloop ' update delay count
pauseus_ret ret
' ----------------- ' Write Byte to device ' ----------------- owwrbyte rdlong value, iodata ' get byte from mov bitcount, #8 ' 8 bit counter mov waittime, cnt ' this is used in all waitcnt add waittime, 4_34delay wrloop shr value, #1 wc if_nc mov usecs, shortdelay if_c mov usecs, longdelay if_c jmp #:wronebit ' Logic 1 = low or dira, owmask ' Logic 0 = low waitcnt waittime,4_34delay andn dira, owmask ' Logic 0 = high waitcnt waittime,4_34delay :wronebit or dira, owmask ' Logic 0 & 1 = low waitcnt waittime,4_34delay andn dira, owmask ' High till end Time_bit waitcnt waittime,usecs djnz bitcount, #wrloop wrlong ZERO, cmdsel jmp #owmain 4_34delay long constant( ((CLKFREQ / 1_000 ) * 4_340) / 1_000 ) shortdelay long constant( ((CLKFREQ / 1_000 ) * 25_980) / 1_000 ) longdelay long constant( ((CLKFREQ / 1_000 ) * 34_660) / 1_000 )The calculation of the delays is like that because we are in integer domain. So, only dividing by 1_000 (=> shift to ms) in the first step keeps as much digits as possible whilst avoiding an overflow.( CLKFREQ/1_000_000 * time is the general formula, but does not work good in integer domain. )
This is the quick and dirty implementation, because in the long periode you add some time to the waitcnt for the code which runs until setting the next start-bit. But this should be deviation which does not make problems because we talk about <1us.
If you want it completely perfect you can simply move the waitcnt usecs to another position and do it after all the code that gets the next bit.
rd[COLOR="orange"]byte[/COLOR] value, iodata mov bitcount, #8 mov cnt, cnt mov cnt, #9 :loop waitcnt cnt, [COLOR="blue"]short[/COLOR] or dira, owmask ' low waitcnt cnt, [COLOR="blue"]short[/COLOR] andn dira, owmask ' high shr value, #1 wc ' sample bit waitcnt cnt, [COLOR="blue"]short[/COLOR] muxnc dira, owmask ' low/high waitcnt cnt, [COLOR="blue"]tail[/COLOR] andn dira, owmask ' high djnz bitcount, #:loop waitcnt cnt, #0 ' guarantee last bit tail wrlong ZERO, cmdsel jmp #owmain short long 347 ' 4.3375us @80MHz tail long 2079 ' 25.9875usTo answer your question, the logic is OK. But as mentioned earlier, having dedicated delay code is overkill here. I removed an earlier comment as for some unexplained reason I had [thread=137206]a 0.1us delay[/thread] stuck in my head (too much alcohol maybe).Thanks Mark. So that's why its #24.
Got it. Yes, I understand now. I'll implement delay calculation in this manner instead. Thank you MagIO2.
Hey Marko! Thank you but it took me quite a while to understand ... sorry I have some questions:
1. what does this means? I thought cnt is a register & cannot be used as a destination operand?
mov cnt, cnt mov cnt, #92. I like this!
shr value, #1 wc ' sample bit : muxnc dira, owmask ' low/high3. I'm a little confused, when its logic 0:
: waitcnt cnt, [COLOR=blue]short[/COLOR] muxnc dira, owmask ' low/high waitcnt cnt, [COLOR=blue]tail '<---- should the "waitcnt cnt, short" be here and ...? [/COLOR] andn dira, owmask ' high djnz bitcount, #:loop [COLOR=#0000cd] '<---- should the "waitcnt cnt, tail" be here before the djnz ?[/COLOR] :4. I don't see how adding #0 to waitcnt means the tail is selected?
0.1 usecs ...
Note "shadow RAM' is the actual RAM location that exists at the cog memory address used for some register. There's a RAM location corresponding to each of the Prop's I/O registers, but they're only accessible under some circumstances because the I/O register takes precedence when processing the source field of an instruction. When processing the destination field of an instruction, the shadow RAM location is always written. The I/O register is read when it's read-write, but the I/O register is not used when it's read-only. Instruction fetches always use the shadow RAM.
So, does it explains the reason why Marko added #9 to factor in the cycle time for the previous MOV & this WAITCNT instructions so that the pulse duration is as accurate as possible?
So, is this shadow RAM something like cache? I won't get such jems from the manual ....
And don't confuse cog RAM with hub RAM (hub RAM is byte-addressed, cog RAM is long-addressed)
The manual does describe this as far as I remember (particularly in the descriptions of the various special registers).
In PASM waitcnt works slightly different (compared to SPIN that is). It waits for a match on its dst value, then adds src for the next match.
:loop waitcnt cnt[COLOR="orange"]{ref or ref+3*short+tail}[/COLOR], short or dira, owmask waitcnt cnt[COLOR="orange"]{ref+short}[/COLOR], short andn dira, owmask shr value, #1 wc waitcnt cnt[COLOR="orange"]{ref+2*short}[/COLOR], short muxnc dira, owmask waitcnt cnt[COLOR="orange"]{ref+3*short}[/COLOR], tail andn dira, owmask djnz bitcount, #:loop waitcnt cnt[COLOR="orange"]{ref+3*short+tail}[/COLOR], #0HTHAfter going thru your code for long while (including talking to myself), I finally understood =D !!! Thank you very much Marko! Yes, its a very different mind-set for me. Have a good weekend All.
Thank you Mark.
